The camera will not focus on anything more than a few feet away, which isn't real noticeable at wider angles, but at longer lens lengths (105) everything is fuzzy.
SOURCE: autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
SOURCE: Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do
is to take it to the nearest official Canon repair shop and Canon should
fix it for free.
If your camera is out of warranty, or if Canon refuses to repair
it for free (happens sometimes if for example they suspect the
camera has not been treated properly) you can try some of
the methods listed here to repair it yourself. These simple methods
have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry
compressed air (20 lbs) set the tip between the lens turret and the
camera body and turn on the air while moving the tip around the lens.
It should remove all dust and sand. Turn the camera on and it should
function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very
often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and
the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to
fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a
"click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the
camera off. Take the camera in one hand and with the other gently take one part of the lens and gently
move it round in a circular movement. Do so with both sections of the lens. You will hear a "click"
as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning
the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and
off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)
It is a great guide with pictures and it can be found here.
regards
iversh
a very helpful rating is apreciated for answering ur query.....
SOURCE: I had the E18 error--lens wouldn't retract and
Focus problems are quite common after a lens error, it sounds like you still have an issue with that lens unit. If you need help, there's a great site taht just specializes in the powershot problems, nothing else at all. Try going to www.camerasandparts.com and you'll see the fix for this for your SD890 camera. I hope that helps, that site is amazing for the powershots and that's where a lot of people go for help with these. Good luck with it.
SOURCE: I slightly dropped my Canon
The only suggestion I have (that might not be a camera fault) is to make sure that you have not left the camera in Macro mode. This is a special extreme close-up mode offered by some cameras, and it does not allow autofocus on objects at normal distances. The icon for Macro mode is a little flower. On my Canon, this is selected on the left hand edge of the ring around the FUNC. button.
