Question about Maytag Refrigerators
The freezer has a built in ice maker and not only do I get a layer of ice on the entire bottom of the freezer but we also get water leaking onto the floor. If you can help, please be detailed in your answer as I am not too handy but would like to try and fix this without calling a repair technician. Thank you!
Https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Jan 02, 2018
SOURCE: water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Posted on Nov 17, 2008
SOURCE: maytag side by side refrigerator ice forms at the bottom of freez
DEFROST THE FRIDGE BY SWITCHING IT OFF FOR 2 DAYS
Posted on May 25, 2009
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
SOURCE: My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Posted on Apr 20, 2010
SOURCE: Ice maker not making ice
check the water solenoid for the ice maker on the back
Posted on Jun 11, 2010
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Mar 20, 2010 | Refrigerators
Jan 17, 2010 | KitchenAid KBL36FM 36" Built-In...
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Nov 16, 2008 | Refrigerators
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Oct 28, 2007 | Refrigerators
557 people viewed this question
