Question about Maytag MSD2651 HE Side by Side Refrigerator
Do i need to clean coils?
I pulled the refrigerator out and see no coils. How do i clean coils?
Posted by William Stahovec on
amardeep singh
    New Friend:
1.Determine whether your Kenmore refrigerator model's coils are located at the bottom-front of the refrigerator or on the back panel. If they are on the bottom front, remove the plastic grill kick-plate by pulling it up and lifting it out.
2.Vacuum your Kenmore refrigerator coils thoroughly to remove all of the dust and debris.
3.Use a coil brush available online or at any hardware store. Insert the brush between the refrigerator coils and pull it back out. The coil brush will remove dirt from between the coils that a vacuum will not.
Posted on Sep 23, 2012
tradmker
    New Friend:
You dont new unit are sealed, some have a filter in front at the bottom vent.
Ge gss25wgpa
Typically on most household refrigerators there is a kick plate in the front of the refrigerator on the bottom, that usually is just clipped on either pulls out or lifts up and pulls out. If there is nothing there, then unplug the refrigerator and there is usually a handful of screws that hold a access panel on, it will be towards the lower part of the refrigerator. Remove the screws and the access panel.
(be sure the unit is unplugged for safety)
from there the condenser coil is typically is located towards the front of the refrigerator, you can use either a shop vac, or a coil cleaning brush available at a hardware store, and clean the condenser coil off.
Then re install either the panel or the kickplate, and plug the refrigerator back in.
Be sure not to disturb the wiring or the piping and you should be fine, if unsure of what to do, then I recommend not doing it......
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Jul 08, 2013 | Refrigerators
Tip
Cleaning your coils.
<span>Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.<span> </span><span> </span></SPAN><br> <span>Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.</SPAN><br> <span>Reinstall the pan and the grill.</SPAN><br> <span>Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.</SPAN><br> <span>If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.</SPAN><br> <span>If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.</SPAN>
on Feb 23, 2011 | Refrigerators
Whirlpool refrigerator clean coils
For most machines, there is a kickplate located at the lower portion at the front which can be pulled off to expose the coils. You can either use a coil brush or a vacuum with an attachment to clean them
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 31, 2012 | Whirlpool Refrigerators
My daughter's fridgidare top mount freezer blowing out cool air but not keeping things froze , can freon be put in it , fridge is only about 5 yrs. old
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
Floor Level Coils
You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils.
Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Rear-Mounted Coils You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Jul 10, 2011 | Frigidaire Refrigerators
The freezer is running and is set to the coldest setting but still is not cold enough to freeze our food. Ice has melted and food in the freezer is beginning to thaw.
1. Make sure condenser is clean.
2. If you have a "rear mounted" condenser (black coil on back) make sure it has enough room around it for air to circulate. Not against the wall and if under cabinet should have about six inches clearance.
Rear-Mounted CoilsYou should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant.
Floor Level CoilsYou should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils.
Jul 10, 2011 | Amana ARB220RCW Bottom Freezer...
I just bought a used refridgerator and it seems to make a buzzing, rattling noise at times then stops. Then it will start again later. The girl I bought it from said the coils may need cleaned or it may...
Hi there
The noise is a very annoying thing in refrigerators but to stop these please do the following.
Pull the refrigerator away from the wall and unplug it.
Find the condenser coils on the refrigerator and clean them. These coils disperse heat, so cleaning them improves the effectiveness of the refrigerator which helps to stop the refrigerator from buzzing. To locate the coils, you will need to check your refrigerator owner's manual as they may be rear mounted or floor mounted coils.
Remove the dust build up on the condenser coils with a vacuum cleaner or condenser brush. If there is a large amount of build up on the refrigerator coils, you can use mild soapy water to more thoroughly clean them.
Clean the grill on the front of the refrigerator as it will also help eliminate the noise. The grill on front of the refrigerator should snap off and on, but check for screws first. Then pull firmly toward you to remove the grill.
Do these troubleshoots and the buzzing should stop
Sep 02, 2010 | Refrigerators
My refrigerator and freezer worked fine until after a power outage. Now the unit will not cool at all, and the fan runs constantly. What should I look for?
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously(non stop fan action) or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Now, Once the coils are cleaned, simply re- introduce power to the unit, and observe for a couple of hours. If the fan continues to run, and there is no cooling affect, this will indicate that the main control aboard(PCB), is damaged. It must be replaced in this case.
Dec 27, 2009 | Kenmore 64802 Top Freezer Refrigerator
Not blowing cold in freezer or refrigerator. compressor is hot to touch, fan is blowing
HI. The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the electrical components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Dec 08, 2009 | Kenmore Refrigerators
Compresor is hot and refrigerator it doesn't work
HI. This will occur if the condenser coils are dirty. This will inhibit the coils from dissipating heat.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Nov 25, 2009 | Maytag Refrigerators
Coil freezing up
An a/c coil freezes up because there is no heat load on the coil. It's either dirty, low on refrigerant, filter dirty, the fan is not running. Defrost the coil by leaving the unit off until defrosted. If the coil is accessible you use a coil cleaner thru a chemical sprayer and spray coil. Do not use the stuff they sell at Home Depot or Lowe's they don't work. get some from an a/c contractor or supply house. After with the chemical sprayer rinse the coil with water. You may have to repeat a couple of time to get it good and clean. If you can not access the coils then you will need to pull and clean the coils. To do this you'll need to pump down the refrigerant into the condenser coil and cut the evap. coil out of the system clean and reinstall. With this you'll need refrigerant gauges and know how to solder and have access to refrigerant. The same if your low on refrigerant you,ll need access to gauges and refrigerant. Depending on system it's either R-22 or R-410 refrigerant.
Sep 27, 2008 | Heating & Cooling
Maytag MSD2651 HE Side by Side Refrigerator Logo
453 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
