Samsung N150 (36725723009) Netbook Logo
batrisyia Posted on Sep 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pink screen many neon pink lines across the screen
Anonymous
Level 3:
  • Samsung Master 32,281 Answers
  • Posted on Sep 24, 2012
Anonymous
Samsung Master
Level 3:
Answers
32281
Questions
Helped
7912504
Points
102259
If the pink lines or streaks are across the screen then this indicates the CCFL lamp will fail soon.
To confirm it is not the video chip on the motherboard, connect an external monitor to your laptop, power up the monitor first and then boot up your laptop. The video will automatically divert to the external monitor and if the Windows image is normal then this confirms a problem with the CCFL lamp and it needs to be replaced.
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
My Acer net book screen is all pink and has pink lines across it when I boot it up- what is wrong?
your screen might have some pixels defect, try to boot your machine to your BIOS mode and if it still shows in there then you may want to contact your computer company for a repair or replacement of your screen.
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
5helpful
I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Neon Pink Lines
"eprom upgrade" by Panasonic tech will solve the problem.
LCD screen has fine pink lines and is changing colors
The LCD might have developed a fault. First try and ensure that the flexible film kind of connector is firmly in place and not damaged. As a final resort the LCD is to be replaced. For spares requirement you can write to me. If it is under warranty pl.try the nearest Sony service center. Sivaram [email protected]
5helpful
5answers
Problems with the picture on my tv. Pink lines across its screen
take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
