Magic eye light is on, but the remote control doesn't work anymore
The red light is on on the back of the magic eye, but all of a sudden it has stopped working, i cannot change channel in the 2nd room where the magic eye is
Posted by Graeme Melville on
ernesto cuadra
    Top Expert:
  • 12,223 Answers
Open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Posted on Sep 23, 2012
5 Related Answers
andy4254
andy williard
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
Anonymous
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
masterof o
  • 4 Answers
SOURCE: Hunter Remote Control # 27185
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Posted on Mar 31, 2009
Jim Franks
  • 374 Answers
SOURCE: 118575 remote stopped working
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Posted on Apr 10, 2009
Anonymous
  • 37 Answers
SOURCE: dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Posted on Jul 06, 2010
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
I am trying to unlock the region code for Sony BDP-S5100 with the URC7740. The hack program refers to "press and hold the &#147 key. Where or what is "&#"?
I would have to guess, that is probably not the correct remote. I feel I must inform you, trying to upgrade your firmware, from an unsavory hacker, can turn your unit into a brick(doorstop). IMO, proceed with caution.
Jan 14, 2015 | One For All URC 7740 Remote Control
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Aug 08, 2011 | Sony Televison & Video
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
12. Press 00255
14. Hold the magic button until the red led flashes twice.
15. Press 994
17. Press 00095
19. Hold the magic button until the red led flashes twice.
20. Press 994
22. Press 00221
24. Hold the magic button until the red led flashes twice.
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S370 region free
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
My satellite remote control only work at close distance I have canged the batteries I tried it with the other box from bedroom in bedroom they work fine in the sitting room both dont work
Hello Aykuturer,
There are two things that you can try to resolve this problem.
1) most common interferrance for the sky remotes are WII sensors to close to box. or the TV back light is interfearing with it. If this is the case then turn off the WII (if you have one) and try that. If it is the TV back light then you can turn this down or off.
2) If you are still not getting any joy from these then you could always go to EBAY and purchase a Magic Eye / Remote Eye. They are resonably cheap from there.
Once you have got your Magic eye. Connect it into RF OUT 2 at the back of your sky box.
Then with the remote press SERVICES, 4, 0,1, Select then 4 make sure that you turn then power on and then save.
This will sort out any IR problems you are experiencing.
Hope this helps you out, If this does then please leave a thumbs up.
Cheers Little Dish Fitter.
Oct 23, 2009 | Samsung DVD-V4600 DVD Player/VCR
Cannot get my sky guide to respond on my Loewe Articos 32,i think the kids have scrambled the tv remote! Any ideas?
There are several things that can stop your Sky remote from working.
step one:
get a mobile that has a camera on it. point the remote at the camera and press the TV guide button on the remote you should see a little light by looking through your camera. This is because cameras dont like infrared
if you see the light whilest looking from the camera phone then the remote is working.
Step 2:
There can interfearance from devices like WII's or if your television has a back light you can turn this down and see if this is going to make any difference to the sky box.
If it does you know what is casuing the problem.
Step 3:
There may be another solution to your problem. Go onto Ebay and type in there Magic eye. you can get them from Argos but you will be paying 3 times if not more then you can get them off ebay.
once you've got the magic eye. plug this into the back of your sky box into RF OUT 2 this must be in 2 due to it providing 9v to the eye.
on your sky remote press services, 4, 0 1 select. go to Rf setting and turn this option to ON and then go down to save. you should see a little red light on the magic eye come on this is all done.
Now try your remote as normal.
I fit sky and a lot of the HD sky+ boxes have rubbish IR (infrared) so this sorts out a lot of problems.
Hope this helps
Little Dish Fitter
Sep 01, 2009 | Loewe ARC332 32" TV
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
534 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
