Question about Kodak EasyShare DX4530 Digital Camera
My Kodak DX4530 has stopped taking photos The menu comes up the flash works but the shutter do not and the screen is black but I can review previous photos before it stopped working
Posted by Fred Cook on
Russell Sulzer
    Genius:
  • Kodak Master
  • 1,019 Answers
Your DX4530 has encountered a system failure, needs to go to shop.
Posted on Jan 24, 2013
5 Related Answers
Anonymous
  • 480 Answers
SOURCE: Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 05, 2008
darntoothysa
Thomas D.
  • 489 Answers
SOURCE: kodak dx4530
Hi
It sounds like either your aperture is stuck closed and no light is getting in, or your CCD is defective and it's not converting the light that enters the lens into a digital signal for the camera to record.
Unfortunately this model has design problems, we have probably had 100's of them over the years... I hate to say it, but it's probably time to replace it with something newer.
Good luck from Darntoothysam com
Thomas
Posted on Nov 01, 2008
Anonymous
  • 126 Answers
SOURCE: Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Posted on Jun 03, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: when taking pics with my kodak c913 the lcd screen
If you can check previous pics and menu settings there, isn't a problem with the LCD screenviewer; sound like a problem with the CCD Image Sensor problem.
Check the link and keep us updated.
Posted on Oct 13, 2011
shajanrs
Shajan RS
  • 890 Answers
SOURCE: menu button doesn't work on kodak easyshare dx4530
Perform a power resetting and check the operation.
Posted on Jun 24, 2012
Flashing colours on screen
You have the review feature active and the flashing colors are most likely showing you the highlights and shadows that are too bright or too dark for a good photo. Look for the features in the menu to turn them off or try a factory default reset from the camera menu.
Oct 19, 2014 | Kodak EasyShare V1003 Digital Camera
When taking pics with my kodak c913 the lcd screen is black and you can not see what you are taing pic of. It all works. When taking a pic the flash will even work. when reviewing the pics it is still...
Oct 13, 2011 | Kodak EasyShare C913 Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
How do you set the apeture on a Kodak Easyshare DX4530 camera?
1 In any Still mode, press the Menu button.
2 Press to highlight Exposure Compensation , then press the OK
button.
3 Press to select the Exposure
Compensation setting.
 If pictures are too light, decrease the
value.
 If pictures are too dark, increase the
value.
4 Press the OK button to accept the change.
5 Press the Menu button to exit the menu.
6 Use the camera screen to frame your
subject. Press the Shutter button half-way
to set the focus, then continue pressing
completely down to take the picture.
This setting remains until you change the
Mode dial or turn off the camera.
here is the link for the manual if the details are not clear http://www.retrevo.com/d/ds/progress?doc=9f1ccaf06b7e8ecedf71c821d3c1fb02&rk=0.5443618496384233
Oct 03, 2010 | Kodak EasyShare DX4530 Digital Camera
I can not see image on screen
If you can see the picture before you take it, then the taken picture is black - Camera needs repair at a service shop - aligment.
If you cannot see the picture before you try and take it - The lens shutter is jammed. A repair shop is required. Could be $80 -$200+ depending on parts costs and labour.
These are only probable answers.
Mar 21, 2010 | Kodak EasyShare C310 Digital Camera
I have a dx4530 and when I take pictures, the screen is black. My guess is that there is a battery inside for the shutter and the battery needs to be replaced.
No unfortunantly this is the mechanics of the camera.
DX4530 is no longer repaired by KODAK due to lack of spear parts.
However thay do offer a Trade up option where you can trade your existing camera for a favorable price to a Brand new model.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 13, 2009 | Kodak EasyShare DX4530 Digital Camera
Kodak dx4530
Hi
Thomas
Nov 01, 2008 | Kodak EasyShare DX4530 Digital Camera
LCD wont show the View and No picture
CCD failure most likely. Format the card then try again or a new card. Kodak customer support for more info
Jun 08, 2007 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
