Question about Pioneer AVH-P6500DVD Car DVD Player
I have power from car but stereo has no power
I have power from car but stereo wont work
Posted by shaun williams on
Sean fenner
    New Friend:
Check fuse first
Posted on Sep 23, 2012
  • shaun williams Sep 23, 2012
    have done pulled stereo out and tryed a normal one in it that worked
Hi my Honda CR-V 97 not enough power to hold memory and clock wont hold time ether and resets ever time I restart the car yours very confused
The stereo should have two 12v wires; one is switched power and the other is always on 12v power.
The memory needs always on power since there is no internal battery to remember presets.
Aug 12, 2016 | 1997 Honda CR-V
Why won't my Delco stereo will not power on?
Hi Carol
Their are two possible thing that causes your stereo fail to be working.
1. Power supply terminal is not properly attached.
2. Busted electronic component inside the stereo.
Some stereo, when their is busted component inside, it wont turn on. So you better have it check to authorize technician or by your self.
Sep 13, 2014 | Cars & Trucks
Comple original wiring to stereo
May have to check some fuses
Jun 07, 2013 | 1997 Chevrolet Camaro
Wont power up
Providing you also ran a ground direct from battery, you need a trigger wire from stereo i usually run off power antenna wire.Some stereos have a seperate amp or trigger wire already coming out you just need to run it to amp.
Jun 06, 2010 | MTX Thunder Elite 801D Car Amp
Power to unit and well grounded but wont turn on
There are 2 powers for this stereo. The is a constant power (yellow wire) which holds the memory, then there is an ignition power (red wire) that turns the stereo on when you start the car. Some cars you need to run the red power wire to a fuse that only works when the car is turned on, for example power windows. Only run it to a fuse that is equal to the fuse on the back of the stereo ( more than likely 10a). Oh and btw check the fuse on the back of the stereo under the plug. If none of these work you have a bad stereo. Or you hooked up the wires wrong.
Mar 14, 2010 | Pioneer DEH-P2900MP CD Receiver...
Gmc pickup when i turned on headlights stereo turned off and headlights quit working checked fuses thats not it.and the horn wont work now
THAT SOUNDS LIKE YOU HAVE THE RADIO CONNECTED WRONG.. REMOVE THE ALL POWER FROM THE BACK OF THE STEREO. AND CHECK AGAIN, ONE OF OR TWO OF THE POWER WIRES TO THE ORIGINAL STEREO ARE FOR DIMMING THE LIGHTS NOT TO BE USED AS A HIGHER AMP OPERATION.
Jan 22, 2010 | 1987 GMC G1500
My in-dash won't come on
yellow lead on car stereo should be going to a permanent live on car stereo wiring loom, (always 12 volts regardless of key being in or out) red lead on car stereo should be going to aux in car stereo wiring loom, (12 volts only when key in and ignition lights on) green lead on car stereo goes to earth to allow you to watch dvds whilst driving (highly illigal whilst driving!) read the manual, if this doesnt work fuse in car possibly gone?
May 10, 2009 | Car Audio & Video
Changed car battery and my sony stereo wont work
you probably need to check all your fuses.
May 05, 2009 | Car Audio & Video
97 grand prix se power windows and stereo
there is a wire in the back of the stereo that controls the windows you might have a short if neither is working
Jan 18, 2009 | 1997 Pontiac Grand Prix
Carolla stereo wont turn on..
Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
Cheers.
Nov 09, 2008 | 2004 Toyota Corolla
Pioneer AVH-P6500DVD Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
