I have replace the lamp before but how do I know it's the same problem?
Check this link to get more details. Blinking codes to this TV is described in detail there.
SOURCE: Replacement Lamp Hitachi 50V500
It must be a red light flashing as the 50V500 has no green lights on it. Make sure that when you place the lamp cover back on that it is activting the micro switch behind it. Otherwise the set will assume the door is open and won't ignite the lamp. Otherwise the ballast could be the issue.
SOURCE: My Hitachi 50V500 does not turn on
Most likely...Just remove cover on left side and take a look at the lamp and go from there. I may have one in stock if you need it. You will also need a philips screwdriver.. Happy repairing. Guru Jay
SOURCE: lamp light
Check the lamp switch that is located inside the door. Place the lamp in, and stick a flathead screwdriver in the slot (just make sure it moves) hold it there, and turn on the Tv. If that doesn't work check the new lamp, is it a generic lamp, if so they dont always work. If you still have your old orig lamp, take the old lamp out of that housing, and out the new lamp in the old housing. This should fix the problem.
SOURCE: replaced bad lamp on t.v. and was told there is a reset button
the reset lamp time in in your users manual, and or should come with the new lamp..
SOURCE: hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
