It is a free arm model so not much flat area to use
You can definitely quilt on the Singer Simple 3116! However, I do NOT recommend quilting several different kinds of fabric together. I don't think the machine can handle it, so stick with quilting cottons. I free-motion quilt on mine with the darning/free-motion foot. You can also use an even-feed foot for straight (and only straight...) quilting. I, personally, think that an even-feed is far too expensive and certainly not as versatile as learning to free-motion. You can find both feet here: http://www.searspartsdirect.com/partsdirect/part-model/Singer-Parts/Sewing-machine-Parts/Model-3116/1232/1220000/50033899/00007
You could probably do light quilting on it, you'd probably
need to buy a extension table for it.
here's a link for parts for the the machine, they do have a extension
table you might be interested in.
http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx
SOURCE: SINGER SIMPLE 3116
Cope and paste the following link into your web browser. You can order a hard copy of the manual or download a free copy onto your computer.
http://www.singerco.com/accessories/manuals.html?man_model_no=3116
Hope this helps! :o)
SOURCE: singer 3116 - change the needle
I'm giving you a direct link to the Manual on page 82 of which is explained the procedure of removing the needles so you can attach new ones the same way...
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lemme know if it helps :-)
SOURCE: singer simple comes with limited feet have been unable to find
janome machine feet should fit
SOURCE: top part of singer 3116 is squeaky
Oil the top of the needle bar very lightly and the moving parts of the takeup lever, if you still have it then I would suggect taking it in for a check before it costs a lot of money
Testimonial: "Thank you Thank you Thank you!!!"
