Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
Rekey the dead bolt on a kwikset powerbolt 1000
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: I have a 907 Powerbolt Touchpad Electronic
Take the back off of the deadbolt where you install the batteries. The instructions are inside.
Posted on Jul 07, 2009
Anonymous
SOURCE: kwikset smart key has no key. need to rekey. how
Here is the instructions from kwiksets website
http://www.kwikset.com/Files/PDF/SmartSeries/SmartKeyInsEnglishOnly.pdf
Posted on Oct 21, 2009
Anonymous
SOURCE: how to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Posted on Dec 02, 2009
Coaltowner
  • 963 Answers
SOURCE: how do I errase the
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Posted on Jul 09, 2011
Coaltowner
  • 963 Answers
SOURCE: My numbers on the keypad are worn off of my
Contact Kwikset Customer support:
http://www.kwikset.com/Customer-Support/Overview.aspx
good luck!
Posted on Nov 05, 2011
I forgot the code and I lost the key
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
Aug 03, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
My numbers on the keypad are worn off of my Kwikset Powerbolt lock where can I buy replacement numbers
good luck!
Jan 12, 2011 | Kwikset UltraMax Powerbolt 1000
Locked out of house. After pressing code I hear a long beep bur no bolt movement. How can I get in my house??
Why is my Powerbolt beeping?
This link:
Good luck--and please provide feedback if this helps!
Jan 08, 2011 | Weiser Lock Powerbolt 1000 Lock
DEAD BOLT WILL NOT CLOSE
These installation instructions will work for you . Note the instructions about the directional jumper.
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Jan 04, 2011 | Weiser Lock Powerbolt 1000 Lock
Can you rekey this unit
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000Hiy2AAC.aspx
Nov 24, 2010 | Weiser Lock Powerbolt 1000 Lock
My bolt does net retract it sounds like it engages but it does not move i have the power bolt 1000 help?
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Nov 22, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
I have to change batteries every two weeks. What's wrong with this Powerbolt 1000?
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Oct 12, 2010 | Kwikset UltraMax Powerbolt 1000
The bolt will not move via the power, it does move manually. i also put new batteries in.
Sep 28, 2010 | Kwikset UltraMax Powerbolt 1000
I have installed the Kwikset set smartcode, while it operates correctly while the door is open, when I close it it will beep every 30 seconds, I measured the precut hole for the bolt and it is 11/16 th...
This link:
Sep 23, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Just had my kwikset dead bolt lock rekeyed. i put it back on the door and now you can't pull the key out after you lock the door. please help
Sounds like its binding. Loosen the screws that hold the 2 halfs together. Get the key to work smothly. snug the screws and try again. If ok then tighten the rest of the way.
Sep 24, 2009 | Kwikset Locks & Locksmithing
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
453 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
