Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
do you get a blinking red or green light?>
SOURCE: SONY KP-46WT500 Arched red lines appearing
After all the screws are removed, the panel pops on . They use plastic dowls inserted in rubber. The brightness may need to be turned down on the color that has little lines appearing. The brighness is on the picture tube board on each picture tube. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
SOURCE: I have a sony tv model kdf-50e2000,and it has a
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Testimonial: "Thank you for your rapid response and expertise. This information makes the purchase cost of the bulb seem a bit easier to accept. "
I I opened the back of the TV set and cleaned all three bulb glass lens or scree
The set comes on with sound,all green w/green lines then goes blk& I get red light blinking5 times.Does the bulb have to be replaced?
