SOURCE: Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
SOURCE: light panel doesnt work
this is a common problem.to fix this u need to chge the the top controrl panel assly.it is preety easy to chge.to chge the panel u need to open allthe screws on inside of the door.then the white part of the door can be moved apart.the control panel is held to the outer metal door panel by 4 screws.b4 removing the panel remove the 2 screws which hold the control board to the panel and move away the control board.also u have disconnect the ribbon connector which comes from the control panel and connects to the control board.
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
SOURCE: We have a Quiet series
Hi You are right.... if there is power to the unit so the power
board seems to be working fine and the control panel should be replaced. Hope
this helps...please post back for further assistance. Daniel
