Question about Canon PowerShot A80 Digital Camera
Canon a80 ccd
Ccd faulty
Posted by Paul Williams on
5 Related Answers
t00nz
CameraR
  • 4738 Answers
SOURCE: Canon A70 CCD problems
Recommend sending it off to Canon anyways, but include a short note in the package stating your first three sentences above. Canon should fix the CCD image problem for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Nov 23, 2007
t00nz
CameraR
  • 4738 Answers
SOURCE: powershot A95 ccd problem
This sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Posted on Dec 14, 2007
t00nz
CameraR
  • 4738 Answers
SOURCE: Blurry picture on Canon A80
I don't know what you told that technician, but try this. Download some of your pictures and videos to your computer. If the downloaded pictures look fine on your computer, then the technician was right, and it's probably just a loose LCD ribbon cable connection.
BUT if the downloaded pictures also look blurry with stripes, then it's probably a faulty CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. BUT MAKE SURE you tell the technician this time that it is showing up on your DOWNLOADED pictures. I recommend trying again, and hope for a more knowledgeable tech on the line this time. Please check the following two links for more info:
Posted on Mar 13, 2008
Anonymous
SOURCE: Canon A80 CCD problem or something else?
Open the camera, look at the Flat-cable going from the CCD to the 'camera HW', there is a small connector where the latch mecanism is open,-meaning it does not put pressure on the commenctors and if you touch the flat-cable you can see the flicker/lines, simply use a pen tip to lock the connector latch again, or apply som glue to fix the connector.
Posted on Aug 05, 2008
Anonymous
  • 12 Answers
SOURCE: blurred image on LCD registered when pic is taken
CHECK The memory chip to see if the picture is blurred too.
I think that is over a hundred dollars to repair. call canon and see what they say. but for that much money, you may want to trade up to some newer technologies. many great changes have come true since your model.
Posted on Nov 23, 2009
When I turn the camera on (Canon Powershot A 80) purple and black stripes trouble the screen. The camera takes pictures anyway, but it is hard to see what photograph you make. Can anyone help?
This is known problem of ccd imager chip failure in Canon A80 camera and ccd imager chip will be replaced to fix picture problem.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
Thanks.
Feb 04, 2010 | Canon PowerShot A80 Digital Camera
Cannon PowerShot A80. Pictures come out with red tint and what appears to be horizontal lines across complete image. However, record video without problem.
If camera shows previously taken pictures in playback mode and does notshow live view to take fresh pictures then it is ccd imager chipfailure. CCD imager will be replaced in your Canon A80 camera.
Oct 27, 2009 | Canon PowerShot A80 Digital Camera
When I use the camera to take a picture, the display screen has lines that appear and "jump" around the screen. What is causing this, and how can I fix it? Thanks!
If it is Canon A80 camera then it got ccd imager failure problem and ccd imager chip will be replaced.
Canon offers free of cost repair for few models, A80 included, for ccd imager chip problem.
Click Canon CCD Imager Advisory for details for USA, if you live in another country, please check with local Canon service center.
Thanks.
Oct 22, 2009 | Canon PowerShot A80 Digital Camera
I have a canon A80 AiAF. Sreen Problems
Its known problem of CCD Imager in Canon A80 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jul 19, 2009 | Canon PowerShot A80 Digital Camera
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
Mar 23, 2008 | Canon PowerShot A80 Digital Camera
Nov 20, 2007 | Canon PowerShot A70 Digital Camera
Screen all fuzzy when taking photo.
What you have is a CCD issue. The CCD is the part of the camera that captures the images and stores it to the card. When the CCD goes bad it does some pretty funky things, including blurry, fuzzy or other weird things when they go bad.
Here is a link to an eBay auction with a CCD on it.
http://cgi.ebay.com/Canon-A80-Digital-Camera-Parts-Repair-OEM-LENS_W0QQitemZ250042538561QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 14, 2007 | Canon PowerShot A80 Digital Camera
CCD and viewer
The CCD is faulty-Contact Canon for replacement
Jun 18, 2007 | Canon PowerShot A60 Digital Camera
Canon PowerShot A80 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
