SOURCE: Lincoln mark wont start.....
ive tried turning the ignition on and off three times or so....then turning it off completetly for about five secs and then turning the ignition all the way on and most of the time it starts up....but sumtimes i think this car has a mind of its own......
SOURCE: lincoln mark viii
You will first need to remove the plastic piece behind the inner door handle that you use to pull the door shut with and there should be a 10mm bolt inside there behind the insulation. The plastic cover behind the inner door lever handle will need to come out. It's only in with clips. Remove the reflective lens on the end of the panel and you will see a phillips head screw inside. It's a long screw so be ready for many turns to get it out. Next, your power window controls will need to come out and they are only snapped into place but be careful with them because plastic prongs can be broken off if not pried out in the right direction. The same goes for the door lock switch. Unplug both once out. You will also see a triangle plastic piece (can break easily) towards the front top side of the panel. Make sure it clears it's way out when removing the panel. The rest of the panel is held up with downward facing plastic clips. Sounds hard but really it's all pretty simple. Study the back of the panel before putting it back on and take your time.
SOURCE: where is the location of Lincoln Mark 8 VIII
Air Suspension Compressor Motor/Vent Solenoid : Lower RH front corner of engine compartment C134
Air Suspension Switch : Rear side of trunk C458
Air Suspension/EVO Steering Module : Behind RH cowl panel, above connector bracket C204, C205
Air Suspension/EVO Test Connector : RH side of engine compartment, top of wheel well C117 Soft Ride Relay : Under center front of package tray C403Hard Ride Relay : Under center rear of package tray C404 sorry could not find compressor rely listed, good luck
SOURCE: The heater in my 1998 Lincoln Mark VIII LSC
You have a problem with your blend door actuator. Every year, twice a year, my husband manually moves the blend door actuator and puts a tie wrap on it so it will stay in either the heat or cool position. You can reach this through the glovebox, which you will need to remove. I had this fixed at the dealer once long, long ago - very expensive because the plastic piece that needs replacing means they must remove the seats and the whole dash area including the steering wheel to properly replace what is broken. If you want to see how that is done go here: http://www.mechanixtrix.com/Article/Article.aspx?ArticleID=145 Much easier going through the glovebox.
SOURCE: my fan isn't blowing in my 98 lincoln mark
Radiator fan or AC blower motor? The blower motor will have a fuse and a relay. The radiator fan is controled by the Variable Relay Control Module and temp sensor.... the module is located behind the grill---hope this helps.
