Power went off tried another outlet no power
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
SOURCE: NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Posted on Jul 25, 2009
SOURCE: Crate GX-20M burned resistor + popped cap values?
go to
http://www.crateamps.com/support/index.php
you may find what you are looking for there.
Posted on Aug 20, 2009
SOURCE: looking for a circuit board manual or diagram for
try the Crate Website
http://www.crateamps.com/support/discontinued.phprate
SOURCE: Buzzes and feedback
Make sure the "ground lift" option is used on the direct box.
DO NOT UNDER ANY CIRCUMSTANCES use a headphone output jack as the output of this unit. The headphone jack is for HEADPHONES that have no return to ground. Use of this as drive to a sound board is sure to cause problems and in some cases can fry these amps due to the circuitry.
The cable used to go to the direct box should be very short and high quality.
You should source the power for this unit from the SAME source and receptacle as your sound board if at all possible.
Posted on Nov 08, 2009
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Feb 06, 2014 | Crate FlexWave FW120 Guitar Amp Combo w...
Feb 12, 2012 | Crate Music
Sep 22, 2010 | Crate TX 50DB Battery Powered Guitar Amp...
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Dec 14, 2009 | Crate Music
Nov 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Feb 11, 2009 | Crate Blackheart BH15H Handsome Devil...
Sep 08, 2019 | Crate Music
Jul 18, 2018 | Crate Music
97 people viewed this question
