72cc
Spark plug and air filter open the muffler and clean off the screen inside
Posted on Sep 29, 2012
SOURCE: hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 15, 2010
Jun 19, 2017 | Garden
Oct 17, 2016 | Kymco Motorcycles
May 09, 2016 | Garden
Mar 30, 2016 | Garden
Feb 07, 2015 | Cars & Trucks
Aug 23, 2014 | Motorcycles
Jan 28, 2013 | Pit Cycling
May 24, 2011 | 2007 Honda CRF 70 F
Jul 04, 2009 | 2005 Honda CRF 100 F
Mar 01, 2021 | Garden
96 people viewed this question
