Question about Leviton 1755 Triple Rocker Switch Decora
Wiring triple rocker switch - Leviton 1755 Triple Rocker Switch Decora
1 Related Answer
CaptAdams35
Christopher
  • 28 Answers
SOURCE: triple rocker switch to control 3 function bathroom fan/light
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Posted on Mar 09, 2010
Wiring diagram for levinton 1755 switch
http://waterheatertimer.org/How-to-wire-switches.html#triple
Triple switch wiring with neutral in box and neutral in light fixture
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 11, 2014 | Leviton 003-1755-W Three Rocker Switches
I took the front panel off to paint it and I need to know how the 3 wires on the rocker switch go back on.there are 3 wires that go on the rocker switch there is 2 orange/2 blue/1 black
There are a lot of devices with rocker switches, what is it. You say there are three yet you enumerate five wires??? If I don't get back somebody else could.
Jan 24, 2014 | Electrical Supplies
How to wire tree seperate lights
Not sure from your description.
Copy following link:
Add a comment for follow-up
Mar 24, 2013 | Leviton 1755 Triple Rocker Switch Decora
How do i hook up 3 function switch
1) Copy following link to see wiring diagrams:
2) There are two basic wiring type, depending if power wire and neutral arrive in switch box first, or power wire and neutral arrive in ceiling box.
3) Most homes, the power wire is in ceiling box.
In this case, a minimum of 4 wires are needed between ceiling box and switch.
Dec 09, 2012 | Leviton 1755 Triple Rocker Switch Decora
Went to switch on fire switch blew up i have changed fuse in plug thats all ok so i think the triple switch is blown .
To purchase a new 3-way rocker switch, contact Dimplex Tech Service 1-888-346-7539.
Hope this helps and thanks for choosing FixYa.
Sep 22, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I need to find leviton 1755 in brown
You could use 3 brown single-pole despard switches
Otherwise I cannot find source for triple rocker in brown.
Apr 30, 2011 | Leviton 1755 Triple Rocker Switch Decora
I replaced a triple pole switch. Now only one switch works. Any advise?
If I understand correctly, you replaced a triple pole switch with another triple pole switch?
The key to replacing electrical devices is noting color of each screw.
Hot goes to dark screw.
Load wires going to each light connect to brass screws.
Neutral wires do not connect to switches.
Electricians don't guess, they test.
Separate wires for testing.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
This is the wire that comes from circuit breaker.
Hot wire connects to dark screw.
Connect each of the other wires to brass screws, and use switch to test which wire goes to which Load.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Cooper Wiring Devices Triple Deco Single...
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
HOW DO YOU REPAIR SWITCH ON A RAINBOW VACUUM?
Use a thin screwdriver or some other something like a butter knife and slide it into the gap on the side of the power switch. THis is just a plastic rocker that actuates the actual switch. Pry up on one side a little then the other to work it out. Don't worry if you break it, you can get a new one when you purchase the switch for around $5. Once you have that off, the switch can be pried up in a similar manner. It just unplugs from the socket.
You can purchase switch and cover rocker at goodvac dot com at a significant discount over other sites. Fast delivery too.
Oct 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Triple rocker switch to control 3 function bathroom fan/light
Mar 08, 2010 | Leviton 1755 Triple Rocker Switch Decora
Leviton 1755 Triple Rocker Switch Decora Logo
60 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
