I can't access digital tv and dtv menu is not showing up nor is plug and play.....keep pressing info menu mute power but nothing.help meeeeeeeeeeeeeee
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
