Olympus Camedia E-20N Digital Camera Logo
A
Anonymous Posted on Nov 21, 2017
Olympus digital camera E 20
My camera has 5.0 megapixels. I was photographing horizontally and then vertically and as I shifted my hands I pressed a button somewhere on the left hand side of the camera and the screen went totally black. I cant get any thing thru the lens or viewfinder any more- it has gone completely black and I have tried everything-
5 Related Answers
Anonymous
  • 919 Answers
  • Posted on Dec 11, 2008
SOURCE: Olympus FE-210 White LCD screen
Sounds as if this is a repair issue with the image processing chip inside the camera. You may want to call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
Anonymous
  • 919 Answers
  • Posted on Apr 09, 2009
SOURCE: Olympus FE-20 Digital Camera lens knocked out of place
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $48.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Anonymous
  • 919 Answers
  • Posted on May 18, 2009
SOURCE: Lens not setting back
The problem you are describing is a problem with a sensor that has failed in the lens assembly of the camera. It needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Anonymous
  • 8619 Answers
  • Posted on Jul 10, 2009
SOURCE: I accidently dropped my 1050 sw olympus digital
Hi
This has happened due to failure of lcd controller or due to a flex cable misalignment. When your camera was dropped, the cable connecting the lcd with the main board might came off and needs to be reconnected back. However, if you want to be sure its the flex cable and not any lense issue, you'll need to connect your camera with the computer and check whether all pictures you clicked after the camera gone bad are fine?
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Anonymous
  • 2761 Answers
  • Posted on Nov 08, 2009
SOURCE: the camera turns on - but you cant take a picture
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
I need instructions for operating an olympus camedia e-20 5.0 megapixel camera
quick start guide:
http://www.olympusamerica.com/files/oima_cckb/E-20N_Quick_Start_Guide_EN.pdf
reference manual:
http://www.olympusamerica.com/files/oima_cckb/E-20N_Reference_Manual_EN.pdf
Want to use the timer on my Olympus /FE-230 7.5 megapixel camera tomorrow morning. Need step by step instruction please. Sorry, I can't find my book. Thanks, Sandy
Press down on the cursor pad (marked with a one-handed clock) to toggle the self-timer. Start the self-timer by pressing the shutter release button.
You can download the manual from the manufacturer's web site at
http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1283&fl=8
I have a Sony DSC T-90 12.1 megapixel. I often
The vertical line can be caused by a very bright object in the image like a lamp or a silver surface reflecting the flash.
The spots are caused by the flash being SO close to the lens. Any object that can reflect the flash reflects it right back at the camera. This is an image problem with most point and shoot digitals. Watch for reflective surfaces and stand at an angle to them. Turn on more lights in the room before using flash. Stand at a slight angle to the image or person you are photographing - don't shoot straight on. (I kneel down and shoot up - makes a good shot too.)
If you are shooting toward the sun, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
1helpful
Blurry photos - Olympus Digital Camera
Hi there make sure when your click a snap that time your hand not shaking. After that if you face the same problem then there is a chance of lens error. Its new so your camera under warranty. Just visit service center or Olympus outlet, they will replace the camera. Another thing you can set a shock absorber mode before click the snap from camera setting option . Just try those and please give me a feedback.
My Olympus x-42 12 megapixel camera. Flash broken?
My new camera seems to be eating away at my batteries. I have only had it since xmas and already have been through about 20 batteries. Is my camera faulty?
Oct 19, 2009 • Cameras
2helpful
Olympus u-mini 5.0 megapixel - no picture
YES - I had the same problem, sent it to Olympus the repair would cost £128.89. I told them to STUFF it. My advice is buy NIKON. Olympus had the audacity to say "the electronic system requires attention" - as if I needed an engineer to tell me that!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 27, 2009 • Cameras
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
A horizontal or vertical red line appears on picture.
Red lines are caused by glare. Avoid photographing shiny surfaces that reflect excessive amounts of light into your lens.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
