SOURCE: I have been offered a Netgear N150 DGN1000
Well this product DGN1000 is a generic router supplied by Netgear and can be used with any ADSL/DSL ISP. Please ensure that you upload the latest firmware for this router from the netgear support site and then you can use it with other ADSL/DSL ISP.
Hope this allows you to resolve the issue. If you need further assistance then let me know.
Regards
Anand
Testimonial: "Thanks for your reply, that answers my question. cheers!!"
SOURCE: I have ip pbx behind
Your best bet is really to put the PBX in front of the router instead of behind it. This will come in handy both to solve this issue and to avoid trouble in the future. I myself have my voip box behind my wifi router.
If you do not want to do this, you need to fix your ports as that is what is causing the silence described. Rather than forwarding the individual ports, you may want to set the DMZ to the IP address of the PBX. You only do this if you have the PBX behind the router. Putting the PBX's IP as the DMZ will allow the PBX freedom with whatever ports it tries to access.
Either way, putting the PBX in front would be ideal.
Good Luck!!
EJ Kudelka
SOURCE: how to install wireless modem
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . For use wireless click on wireless then turn on the wireless or enable it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
