SOURCE: Cannot sight in riflescope for elevation, adjustment is maxed out
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
SOURCE: Hello, I have a Ruger 10/22 Target rifle with a
Hi.
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this explains why the bullet seems to rise and fall at different distances. its not unusuall infact it will happen in 99.9% of firearms unless the firearm is set to a "Flat Trajectory" zero.
It seems like your fairly new to shooting and the "Exterior Ballistics Effects on a Bullets Trajectory"
my suggestion is that you take the time to read and DL or buy this software.
Sierra Infinity V6 Ballistics Software (i Dl'd it) and it is fantastic.
along with that they have a long range shooting simulator that will teach you about the mathematics of shooting and allow you to get some in expensive practice away from the range and prying eyes. This software will teach you to
1) Range a target just by looking at it in the scope
2) determine Elevation adjustments
3) Windage Adjustments
4) Accomodate the most daunting of variables for the amatuer shooter the weather
(any shooter can learn how the gun fires on a perfect day. it takes a good shooter to take into account the Barometrice Pressure, Humidity, Elevation (from sea level), and Temperature. And be able to hit the first time)
Regardless of your skill level this software is indispensable it will teach you the cores you need to know for when your software is broken or your pc is broken or its just not fiesable at the time.
it will increase the range from which you can shoot. (in 4 hrs i was shooting to 6oo yards, in two days 2100 yards)
ill check back incase you need other info like how to determine zero by inches of center
SOURCE: Bushnell Banner .22 scope with loose part inside.
It would be better to replace the minute you disassemble a scope unless resealed with special equipment it will never function as well nor will it be reliable and for a bushnell by time you payed for shipping to and from a repair place you'd be at cost of new so might as get new one which has newer glass types that are vastly better than 20 yrs ago
SOURCE: bushnell banner lite sight where do you put in new
replace batteries by removing top of on/off switch- battery type is 357 eveready
