Question about RCA Lyra RD1021 MP3 Player
Rca lyra rd1021
I loaded music on device and sd card and when i turn it on it only flashes RCA and will not do anything else
Posted by Rita Lewelling on
5 Related Answers
Anonymous
  • 175 Answers
SOURCE: my rca rd2762b lyra
I think you have to reintall the software or is your skip button stuck? also this happens when you get water in it.
Posted on Aug 31, 2006
Anonymous
SOURCE: rca lyra RD2212A problem
I formated mine with G-Parted in Linux and it is happy again
Posted on Dec 22, 2007
Anonymous
SOURCE: RCA Lyra RD1021 mp3 player stuck on one song and no sound comes out
Upgrade the player's firmware following the RCA's website instructions (goto support, RD1021, Software upgrades)
Posted on Feb 28, 2008
Anonymous
SOURCE: Unable to download songs onto SD card
umm i just want to learn how to put stuff onto my sd then on my wii
Posted on Sep 22, 2008
Anonymous
  • 12 Answers
SOURCE: RCA Lyra RD1080 extra disk recognition
the card is to larg for the mp3 player use up to 1gb only and do not delete the files that came with the mp3 player or your player will not work use 64k not 32 works better use windows midea player to put music on it mp3 and wma only
Posted on Apr 20, 2009
Cant get the software installed
Why use software.. when you plug it in it comes up in My Computer as a drive......click the drive and you notice youll see all your music just like pluging in a flash drive so ur able to add or delete your music....never use the softeware...allways down the road the software becomes corrupted and ur device ends up not working.....to look at ur internal music pull out ur SD card then plug it in again it will come up like a flash drive and to look at ur external music plug in ur device with the sd card in it...good luck
Dec 19, 2009 | RCA Lyra RD1080 MP3 Player
I NEED TO FIX THIS
First off, let's talk about the bad news: there are a lot of people who complain about just how picky the Lyra is about which SD cards it can work with. Indeed, the later model Lyra devices on the RCA site itself say "now supports more SD cards" as a feature. Ouch.
Go to a popular memory card vendor like 4AllMemory and you'll find that a search for Lyra-compatible SD cards shows barely a half-dozen matches Lyra-compatible SD Cards
Another issue: Firmware Update 615 you might need to update your firmware to gain better compatibility with various SD cards:targets this specific problem.
While we're listing all the potential problems, it's also worth reporting that there are some reports of Lexar memory cards that require a higher voltage than regular SD cards, meaning that the Lyra either wont start at all, or its battery drains faster than usual.
Comment from the web on this: "Some Lexar memory cards require at least 2.7v to operate. Some Lyra models only use a single AA battery (1.5v). This MAY mean the mp3 player doesn't have enough power to run the card (depends on if RCA used the right parts to temporarily boost the internal voltage to 3v through a booster circuit or capacitors). This may vary between models and even between different releases of the same model. This also may explain why you can hook the device up via usband send/receive files to the card fine but then have problems after you disconnect (a USB wire can provide some amount of power. My previous nexxtech player would actually turn on without a battery when I plugged the usb wire in). "
Generally, you should be hooking your Lyra up to your PC, then running the standard PC disk formatting utility. But even then, here's what RCA warns:
"We have recently discovered an incompatibility with the RD1080/RD1090, windows XP(Service Pack One) and some newer SD cards. We are presently working with microsoftto identify the best approach to correct the issue. Until a solution is implemented, we suggest that you use MMC cards instead of SD. "
To format an external device in Windows XP, just find the device in your "My Computer" window, then right-click on it and choose Format.... You'll see something like this:
windows-format-disk-options.png (since I don't have a Lyra, this shows the default for my second hard drive. Your settings would be similar, but probably a bit smaller!)
RCA offers zero assistance on the best way to format an SD Card for use with the Lyra, as far as I can tell, so I'll say that my expectation is that NTFS will work, you should use a short, letters-only volume label, and you should not choose either "Quick Format" or to "Enable Compression".
When you're ready, click on Start and it should only take a few seconds for the SD card to be ready to roll with your Lyra.
If it works.
please rank if this helps
May 24, 2009 | RCA H100 MP3 Player
Have a problem with my RCA Lyra RD1021 64 MB
Hi, try to update the software of the player downloading the app from the RCA Website.
Oct 17, 2007 | RCA Lyra RD1021 MP3 Player
BAD OR MISSING SYS FILE AND WHEN I TRY TO FIX IT IT SAIDS NOT ENOUGH FREE SPACE WHEN THERES NOTHING ON IT
I bought a 2gigabyte sd card and put music to it and got the same problem turned out the my lyra only can go up to 1gig sd card my rca kazoo only would go to 512 and get the same problem so check to see what your player can go up to
Oct 10, 2007 | RCA Lyra RD1080 MP3 Player
My Rca Lyra Mp3 keeps shutting down by itself and what must i download to make it compadible with windows vista
Try updating the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/)
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Aug 15, 2007 | RCA Lyra RD1021 MP3 Player
Downloading
connect it to PC and then open Windows Explorer and search for the drive letter that Windows automatically assigned to be your Lyra player. Click on that and look for any folders. Open the song folder (if exists) and then mouse drag your pc song files into this folder. Disconnect USB cable and your songs should be on the LYRA.
Aug 05, 2007 | RCA Lyra RD1021 MP3 Player
Jul 31, 2007 | RCA Lyra RD1021 MP3 Player
Problem with SD card recognition
Try updating the firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/).
If your computer doesn't recognize the player, you'll have to turn it off, remove the battery and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jun 26, 2007 | RCA Lyra RD1021 MP3 Player
Problem using Scan Disk memory card
I had the same problem, and that is what RCA answer me: "... Due to a unique FAT12/16 cluster size requirement, the supplied format utility that comes with the RD1021/RD1071/RD1075 MUST BE used on all SD/MMC cards before they will work in the RD1021/RD1071/RD1075. Once formatted, these cards will still be FAT compatible and should still work with other devices, i.e. RD1080. The format utility can be found under "Programs", "Lyra Personal Audio Player", "RD1021,RD1071,RD1075", "Format Media" once your software has been correctly installed from the included RCA CD-ROM. ..."
Jan 15, 2006 | RCA Lyra RD1072 MP3 Player
Unit displays "RCA" when turned on, nothing else
Update the firmware off the RCA/Thompson site. Likely that the current firmware is damaged.
Nov 17, 2005 | RCA Lyra RD1021 MP3 Player
RCA Lyra RD1021 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
