UPM Programmable Wall Switch Timer Logo
Henry Jazwinski Posted on Sep 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display very dim - UPM Programmable Wall Switch Timer
Gene Haynes
Level 3:
  • UPM Master 5,391 Answers
  • Posted on Sep 22, 2012
Gene Haynes
UPM Master
Level 3:
Answers
5391
Questions
0
Helped
2603852
Points
14124
Posted under UPM wall timer.
Timer model and brand and approx age are unknown.
Is this new installation?
Was display brighter before?
Most timers have 1 year limited warranty.
Buy another timer.
Add a comment.
http://waterheatertimer.org/UPM-timers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Krups Pro KM7000. How do you fix a dim display on it please?
Dim displays are normally caused by failing, bulging or split capacitors on the back of the display. They regulate voltage to the display. If you are proficient with a soldering iron, you can do it yourself.
https://www.google.com/search?q=Krups+Pro+KM7000+dim+display
1helpful
2answers
1998 Cadillac DeVille electrical?
Interior Lights Dimming Circuit Description
VF Displays
When the ignition switch is in the RUN position, the instrument cluster activates its VF display. The instrument cluster also coordinates the display illumination for the radio (IRC), the cellular telephone (PHN), and the climate control Panel (CCP) anytime the ignition switch is in the RUN position.
Incandescent Dimming 1 (INC DIM 1)
The INC DIM 1 consists of lamps powered by CKT 8 (GRY). These are referred to as the park lamp backlighting because they are only active if the park lamps are on and the ambient light sensor indicates darkness.
Incandescent Dimming 2 (INC DIM 2)
The INC DIM 2 output is used as a general interior light source and an illuminated entry feature that provides interior lighting. The INC DIM 2 consists of lamps powered by CKT 1244 (BRN). When one or more of the following conditions occur, the INC DIM 2 lamps will be active:
• The interior lamps switch is active.
• The park lamps are on and the ambient light sensor indicates darkness
• The ignition switch is in the RUN position and the ambient light sensor indicates darkness
• A Class 2 message is received from the body control module (PZM) indicating that the courtesy lamps are active.
Dimming
The instrument cluster controls all of the interior dimming functions. The instrument cluster receives an ambient light level input from the ambient light sensor and determines whether it is light or dark. If the ambient light sensor is inoperative, the instrument cluster will assume a condition of darkness. Dimming of the VF displays is only allowed when the ignition switch is in the RUN position, the park lamps are on, and the ambient light sensor indicates darkness. If all conditions for the VF dimming are met, the instrument cluster uses the input from the potentiometer in the headlamp switch to determine the level of dimming. The dimming level is sent to the radio (IRC), the cellular telephone (PHN), and the climate control panel (CCP) via a Class 2 message. These modules then adjust the dimming level of their VF display. The instrument cluster provides dimming control of the incandescent lighting through the INC DIM 1 and INC DIM 2 outputs. The instrument cluster provides dimming control of the electronic PRNDL LED through CKT 1382 (PPL/WHT). The dimming level will very based on the potentiometer in the headlamp switch whenever the parklamps are on and the ambient light sensor indicates darkness, regardless of the position of the ignition switch.
1998 Cadillac DeVille ' DeVille, Eldorado (VIN E/K) Service Manual ' Body and Accessories ' Lighting Systems ' Diagnostic Information and Procedures ' Document ID: 489166
Interior Lights Dimming System Check
Step
Action
Normal Result(s)
Abnormal Result(s)*
Turn the ignition switch to the OFF position.
Place the interior lamps switch in the ON position.
All incandescent lighting on the INC DIM D2 output turns ON. INC DIM 2 includes all of the lighting on CKT 1244 (BRN), which is the backlighting for the headlamp switch and the floodlighting for the vehicle doors.
Incandescent Lamps Inoperative
Place the interior lamps switch in the OFF position.
Turn the ignition switch to the RUN position.
INC DIM 2 lighting turns OFF.
All of the VF displays light. VF displays include the following components (if equipped):
• The radio (IRC)
• The cellular telephone (PHN)
• The driver information center (DIC)
• The instrument cluster (IPC)
• The climate control panel (CCP)
• Vacuum Fluorescent Displays Inoperative - All
• Incandescent Lamps Always On
Cover the ambient light sensor with the twilight OFF.
Place the headlamp switch in the PARK position.
The park lamps turn ON.
All of the VF displays dim in order to match the current dimming control level. All of the incandescent lighting for INC DIM 1 and INC DIM 2 light at the current dimming control level. INC DIM 1 includes all of the park lamp backlighting on CKT 8 (GRY) which is composed of the following components:
• The radio (IRC)
• The front cigar lighter
• The steering wheel controls
• The heated seat switches
• The auxiliary blower switches
• The ash tray lamps
• The PRNDL lamp
Exterior Lights System Check
Rotate the headlamp switch dimming control in both directions.
All of the VF displays and all of the incandescent lighting dim and brighten in response to the headlamp switch dimming control.
Vacuum Fluorescent Displays Do Not Dim with Instrument Panel Dimmer Switch
* Refer to the appropriate symptom diagnostic table for the applicable abnormal result.
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Mz rh10 dim display
The display dims except for when you are doing something with it to save power - I hope this is your situation. If it is always dim and going out this is another problem alltogether.
2answers
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
2helpful
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
The unit display is too dim.
Bad news so please don't rate me on this. The display itself needs to be replaced and the part is nla (no longer available)
8helpful
2answers
Display dims on certain menu items
The display will dim for certain features that are not available for use in your current configuration or current operation.
For example; if you do not have an antenna plugged in then the selection for the tuner will be dimmed on the display.
Top UPM Hardware & Accessories Experts
David Spradling
David Spradling
Are you an UPM Hardware and Accessory Expert? Answer questions, earn points and help others
