Question about Xante Ilumina Digital Color Press Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
Posted by carlo graphic on
long05891
    New Friend:
  • 13 Answers
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Posted on Oct 07, 2014
2 Related Answers
Anonymous
  • 24 Answers
SOURCE: Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Posted on Jul 23, 2008
puertobori
  • 7733 Answers
SOURCE: please what can I do
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Posted on Nov 10, 2010
Xante fatal error 929
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
131 fatal error
131 code
LED Head Error
131= Yellow Head
Jan 30, 2014 | Xante Ilumina Digital Color Press Printer
C9800 fatal error 145
Toner Feed Switch Error. Toner Lock Lever Open Error
145 = Magenta Imaging Drum
Mar 11, 2013 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
230:fatal error with Xante Ilumina
RFID Reader Not Installed
Check Connections. Replace the RFID Relay Board Replace the Engine Board.
Jan 09, 2013 | Xante Ilumina Digital Color Press Printer
128:error fatal 02
Engine FAN Motor Error
02: Power FAN Error
is the applicable location of the fan connection normal?
If the condition does not change Replace Fan.
Mar 15, 2012 | Xante Ilumina® 502 Laser Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
Jul 21, 2008 | Xante Ilumina Digital Color Press Printer
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
689 people viewed this question
Top Xante Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
