How do you change the lamp in a mod # 980Z keystone projector
I need to put a new lamp in my keystone projector mod# 980Z I do not know how to do it I do not understand the question on the product It is a keystone movie projector that is all I know about it
Ceecee
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Posted on May 11, 2014
4 Related Answers
Anonymous
SOURCE: Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
Posted on May 18, 2008
Marc Gautreaux
  • 50 Answers
SOURCE: After replacing the lamp in
To reset the lamp operation time on a Mitsbishi XD480U:
Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
Notes:
•Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
• Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
• The projector doesn't turn on if the lamp cover isn't attached securely.
• Be sure to reset the lamp operation time whenever you replace the lamp.
• Do not reset the lamp operation time unless you replace the lamp.
Posted on Dec 17, 2008
Marc Gautreaux
  • 50 Answers
SOURCE: What 2 buttons other than the Power button
Notes:
projdoc
jasbo
  • 2239 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
How do I adjust for Keystone on polaview 340 projector?
There is a menu accesible also from the buttons and you can change it there.
Jun 04, 2014 | Polaroid Lamp for POLAVIEW 340 Projector
Projected image too small
Did you replace the lamp with the EXACT type that was in the projector prior to changing it? Sounds like there is difference in lamps.
Feb 26, 2014 | Epson ELPLP42 PowerLite 280 Lamp
DLP Projector BX327-JD lamp cover broke. Need a new cover
you can pick up some plastics instead of it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Feb 14, 2014 | LG BX327 DLP 3D Ready Projector, Digital...
How to replace a ballast on the sharp projector DT
Flip over the projector with the bottom up to you. you will see a panel door front right of the lens. There is one screw to be removed from the lamp panel door. There will be two holding screws that hold the lamp housing in place, remove these. grab the handle and pull up towards you thus releasing the lamp housing assy. Then place the new lamp and firmly press down and then tighten the two screws that held the lamp assy, then replace the cover.
You will then need to reset the lamp timer. by pressing the menu+enter+the arrow button between the keystone and menu button simultaneously.
Jun 05, 2010 | Sharp XR-10X Multimedia Projector
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
How do I make my projector image "square"?
i Believe you need to go into the projectors settings and adjust what is called the keystone, this changes the tilt effect that the projector throws, just keep messing with that setting until you get it how you like it.
Mar 05, 2009 | Sharp NAVITAR 1.2 INCH BUHL LCD LENS,...
Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
Jul 12, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
k24674
