ytengo el mismo problema formeate la pc y de hay para no logro aserla funcionar intaldo los driver,,,tarjeta firewire cables....y no la recnoce mi pc.....ya ni se que hacerrrr
Picture Project was retired years ago, replaced by Nikon Transfer and Nikon ViewNX. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program, such as Nikon Transfer.
Nikon Picture Project has been retired and replaced with Nikon Transfer and Nikon ViewNX. You can get the current versions of all (free) Nikon software from http://support.nikontech.com/app/answers/detail/a_id/61
there is only one kind of firewire cable available.
go to an electronics store and ask for a firewire cable (ieee 1394)
you also need a firewire port on your pc/laptop. if you don' t have one then you should buy a firewire pci card
there is only one type of firewire connection. you need to buy a firewire cable and attach it to a firewire port on your pc/laptop.
if you don't have such a port, you can a buy a firewire pci card.
you need a firewire cable (ieee1394).
you also need a firewire port on your pc. if you don't have one then you can buy a firewire pci card.
they are not expensive.
You need and AV capture card to do that if you dont have a firewire port.
Use the supplied AV cable that came with the camcorder, connect the audio (left/white, right/red and yellow/video) to the capture card AV inputs and start capturing. You can make the setting on the capture card, whether it should be captured in DVD or VCD format
use the USB cable only for still pix. you would need a Firewire cable to be connected from your DV point in your camera to the Firewire port on your PC. Most PCs do not have Firewire readily installed. You can buy it the firewire card IE1994 card - its cheap. the IE1994 card is used for laptops and the other kind is the one you can plug into an empty card slot on your PC. You need to take off the cover of your PC and push in the Firewire Card. Put the cover back on and its plug n play.
Firewire transfers at 10x the speed of USB 2.0. You will never have the problem of dropping even one frame. Its worked for me!!!
