Question about HP DeskJet F4280 All In One Printer InkJet
My computer says printer offline - HP DeskJet F4280 All In One Printer InkJet
Posted by zoeward31 on
Edgar Allan Pagayona
    Genius:
  • 1,447 Answers
Go to printer and Fax from Control Panel, right click on Icon and set printer online. Make sure printer is on and connected directly to computer as well.
Posted on Sep 22, 2012
Hp laserjet 4 plus offline
It sounds to me like you may be using this printer through the JetDirect interface and have the printer assigned a different IP address than what the computer is expecting. For example, if the computer is configured to find the printer at 192.168.1.205 and the printer has an address of 192.168.1.120, you will see the "printer offline" message on the computer but the printer is happily "online" according to its point of reference.
Another possibility is that the computer has the printer configured to "offline" mode. To check this, right-click on the printer and see whether there is a check mark next to "Use Printer Offline." If so, click on that option and that will remove the check mark, returning the printer to online status.
Feb 07, 2014 | HP LaserJet 4 plus Printer
Printer offline
Brother Printer Offline Windows 10 usually relates to a printhead problem and an error message shown will flash on the Screen. lights will keep on flashing as a sign of this Offline windows 10. Caused by some foreign trash inside the rollers of a printer or due to paper jam in Printer and many more PC causes.
If the problem continues, check this blog or call Brother Printer support services or a Printer Support to stop more printer damage.
The point that fixes Brother Printer Offline Windows 10 Easily:-
1. Check The Network Connection Of Your Brother Printer, Due to poor connection, your Brother printer can display offline on the screen. So, check the connection first and make sure the devices are properly connected.
2. Test The Printing Status-Power off the Printer and then power it on back, Press Windows + I keys simultaneously on your keyboard, Click on Devices button.
3. Update Printer Driver, Offline brother printer issue may confront during a print job. So, update your printer driver immediately for making your offline printer online and print hassle-freely. You can visit the official site of Brother Printer and look for the most recent driver. Select a driver that is compatible with your Windows operating system.
If Brother Printer Offline Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
May 12, 2013 | Office Equipment & Supplies
Printer offline which was working earlier
My computer detected printer offline. I have just used to print some documents. So, please advise what is the problem.
Mar 28, 2013 | Canon Black Pixma Mp 280 High Quality...
My computer says my printer is offline. My printer is ON. What now?
go to Printers and Faxes, right click on the printer and choose Use Printer Online
Jan 24, 2011 | Canon MP490 InkJet Printer
My canon mp620 is offline. My at&t modem is working and my computer is online - my computer detects the printer but is offline
The users who are experiencing offline errors while using the Canon printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your canon printer.
Jan 12, 2011 | Canon Office Equipment & Supplies
I made some copies last week and now my printer won't print. It keeps saying it is offline. I've turned it off, changed ports into the computer, shut the computer down, and tried most of the things I can...
  • Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online ' eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz16oE47d1K
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
    My computer says that my printer is offline and won't print but it is on and has a wireless signal.
    Most times if it says offline is because of some kinda settings issue. When my printer tells me it is offline is because IP address changed that was set up in computer to connect to printer. Make sure IP in printer is same as IP in printer settings on the computer. If not just remove the printer and readd it with new IP address. Good luck.
    Jan 11, 2010 | Epson WorkForce 600 All-In-One InkJet...
    When I print something it says the printer is offline.
    I assume the printer says offline. On your computer, check that the printer properties doesn't have it set to offline. If you have Windows, you go into the printers, right click the printer in question and make sure there is no check mark next to the offline option.
    Apr 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
    HP DeskJet F4280 All In One Printer InkJet Logo
    Ekse
    efs_perpends
    efs_perpends
