Dears .. good morning. i have a problem here , this Laptop has the 3G sim card slot , , i insert it .. but nothing happend .. please can you tell me how to activate th e internet connection through this sim card.? many thanks in advance maher amman / Jordan
the sim card should be inserted in the USB drave to connect ,then instal it normally is autoinstal the should work.
There is software available to download from the Acer website. Go to http://us.acer.com/ac/en/US/content/drivers and download both items with "3g" in the title. UnZip the files into a folder, and then run the setup.exe program for both. Restart the machine, and the click the icon on your desktop, which should now exist. The program will say, "device detected" and "wait while activating" or something similar. If the SIM card registers on the tower and there is an existing A.T.T. account associated with it, then there should be no problem. Otherwise you should probably contact A.T.T. support. They may have a newer or different program to download and install.
SOURCE: how can I use Etisalat internet SIM card without the USD modem
No way except you subscribe through Etisalat.
Are u located in Nigeria?
SOURCE: 3g not connecting
I would turn machine completely off remove the battery unplug it them push the power button hold for 2-3 seconds to discharge, place the battery back in plug it back in and restart the computer without the card inserted. Once the computer settles in then retry inserting the card again. If that does not work re-install the driver again with the disc that came with your sim card. If you do not have the driver you can retrieve a download copy at the support and downloads and drivers area of the 3g sim card site. There should be a web address available on the card possibly.
Call tech support for the card if all else fails they will walk you through it. John
SOURCE: How to connect to internet with a dell laptop
sir 1st u make sure WWAN card is installed in ur laptop ..if there is card u have to enable from bios i think Cellular option . check this site... http://www.youtube.com/watch?v=trfkgJEN9QQ software aldo available on site for that... Thanks
