Question about LG Dehumidifier LD650EAL
SOURCE: Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
SOURCE: dehumidifier is saying bucket is full but it is empty
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 05, 2010
SOURCE: Dehumidifier shuts off with a bucket full error
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
Posted on Sep 16, 2010
SOURCE: My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Posted on Feb 25, 2011
SOURCE: I turn on the dehumidifier and the red indicator
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Mar 30, 2011
