SOURCE: can I buy spare shelves
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
SOURCE: AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
SOURCE: finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
