Apple iPod nano Logo
mal harwood Posted on Sep 21, 2012
Unlock code my ipod needs says unlock code but i never put a code on it.
Anonymous
Level 1:
New Friend:
  • Contributor 48 Answers
  • Posted on Sep 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
48
Questions
0
Helped
80571
Points
56
You can unlock your ipod using the remote unlock method.
Get the remote unlock services from the site mobile-unlocker.com
and unlock it easily.
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
How to unlock my ipod
Hi vilmaleo1020
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Need default code for ipod nano the little one never put code and dont know it
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me...
Thank You
1helpful
Cannot unlock
There is not a master code to unlock the ipod- You will need to force restore the ipod to get it unlocked watch the video to learn how. This is your only option !
1helpful
I cannot unlock my ipod touch it says too connect to itunes while itunes says to put in the code the pad does not pop up to put in the code how do i unlock it?
IPod synced with), and open iTunes. When you disconnect iPod from the
all data on your iPod. Afterwards, you can add your music and data back
to your iPod.
with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone.
computer.
Good Luck, I hope this helps
Please Rate me...Thank You
My ipod stoped doing anything, it is locked on screen with message saying I have to wait over 2 billion minutes which is calculated to the ripe old age of 73, cant do anything
The iPod touch becomes locked when an invalid unlock code is entered too many times.
There are two ways you should be able to unlock the iPod.
The first is to connect it to the computer it was last synced with. After iTunes recognizes it, you should be able to unlock it.
If that doesn't work or you can't remember your unlock code, you will need to put the iPod into recovery mode, and then restore the iPod through iTunes.
To do this:
1) Turn the iPod off.
2) Hold down the iPod's Home button and plug the iPod into the computer it was last synced with.
3) Release the Home button when the iTunes image appears on the iPod's screen.
4) Wait for iTunes to recognize that the iPod is in recovery mode, and then follow the onscreen instructions to restore the iPod.
Note: You may lose some of the information stored on the iPod.
If you cannot unlock the iPod after doing this, you will need to call Apple Customer Support.
I forgot my unlock code for my Ipod touch and really need a default code.
There is not a default code to unlock any locked iPod. This would defeat the purpose of the iPod's security.
You can unlock the iPod touch by putting the iPod touch into recovery mode, connecting the iPod to the computer it was last synced with, and then restoring the iPod.
To do this:
2) Hold down the Home button and plug the iPod into the computer it was last synced with.
4) Start up iTunes and after it recognizes that the iPod is in recovery mode, follow the on screen instructions to restore the iPod.
Note: This may cause you to lose some of the data stored on the iPod.
If this doesn't work, call Apple Customer Support.
Cant unlock ipod nano
Hi All,
U guys can try to enter "0000" as a code and check
If its not working try to connect the ipod to compute rand then update the software and the re sync the ipod with Itunes
Reply the status
My ipod is lock how do i unlock it my sister put a code in and it wont unlock.
plug it into your computer.
open itunes.
click on your ipod in the bar on the left side of itunes.
click the button under the picture of your ipod that says "restore". this'll delete all your songs, but it'll unlock the code that your sis put on it, or at least, it should.
if it doesn't do it automatically, click the "Sync" button after the ipod has been restored, and you should be good to go with all your music, and without that code.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
