Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Try to adjust the volume(on dock only) and just keeps getting louder havt to pull ipod
Posted by john banks on
Andy Tobin
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Volume button stuck in. Try and free the button as it may be jammed. It may need to be taken apart to loosen the up volume button. First try prying it up externally but be careful not to break anything in the process.
Posted on Sep 21, 2012
1 Related Answer
Anonymous
SOURCE: with my ipod dockes I am getting a distorted sound
Did you get this solved??
I am having the exact same issue!
Posted on Feb 20, 2010
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
The speaker make a buzzing sound
that's called breaking up or overloading it means that the speaker is being asked to play louder than it was designed to play!! this will ruin the speaker at all volume levels if allowed to make that sound for very long..advice? lower the volume till that noise disappears it's not a product fault it's user error advice turn it down or buy a more powerful unit to achieve the volume you want/need
Dec 12, 2013 | JBL On Stage Micro Speaker Dock for Apple...
My problem is that the remote for my skull candy pipe speakers only adjust the volume but it used to work when i first got it
turn on your ipod before putting it into the dock -make sure dock is on aswell then connect it and you will hear a noise like plugging into the computer and then the whole remote will work !
Dec 30, 2010 | Skull Candy Skullcandy Pipe iPod Dock ...
Hi, I just got the new altec lansing ipod sound dock and a new ipod touch 3rd generation. The dock is not playing sound off of the speakers. Can you help me fix it?
have you turned the volume up from the speakers and the ipod?
thats usualy a problem people get
they think they have to turn volume up from ipod not dock
Feb 17, 2010 | Altec Lansing Inmotion-IM600...
Works great , but Ipod dock only will give about half volume
All Ipod docks bypass the audio processor, so your volume and equalizer presets on the ipod will not work. Use the volume knob on the home theater unit itself.
Dec 20, 2009 | Audio Players & Recorders
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Harman Kardon Go + Play Portable Speaker Keeps Shutting Off
I just had this exact problem. I'm using an ipod mini. I solved it by docking the ipod firmly at the angle
the dock is at and have the ipod at an angle, not flat. I put the plastic and rubber adapter for the mini as instructed and also placed the rubber adapter for the nano upside down to keep
the ipod propped at an angle. (Also can use something similar to keep ipod propped up at an angle)
Took a while when I first used to figure out how the dock worked. The dock is a little weird how it is hinged to go from an angle to flat. Nothing in the instructions about this. By putting the ipod flat it would still have a connection to charge and play but the power shuts off every 10 minutes. I spent a whole night having it shut off every 10 minutes. This drives me crazy when systems have features like that which always seems to cause more problems (just my humble opinion)
By having the ipod at an angle I'm currently just now having it run an hour and 20 minutes and counting with no shut offs,(fingers crossed) but so far so good.
Saw on the internet that if the ipod is not connected firmly the system has an auto shut down. I think the ipod's weight propped at an angle keeps the connection firm. Also some said they want to see the ipod display, there you go!!!! This seems to be working so far for me, may be worth a try...I was about to return mine but I love the sound so I'm keeping mine now!!!! Works fine. Happy camper again.
Please reply if this works for anyone it worked for me.
Jun 30, 2008 | Harman Kardon Go + Play Portable Speaker...
IPod circuit board
SDI Technologies Inc. has part just got tto there page and ask them for ipod dock connector part (part # IH5-101)
Feb 24, 2008 | Audio Players & Recorders
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
161 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
