Purchased dell duo and audio station together. It worked fine. Then a few months ago I noticed that it wouldn't always charge when docked unless I rebooted and put back in dock. Then quit working altogether. My dog chewed the power cord to dock about same time so not sure which happened first. Anyway, purchased new cord, still doesn't work. Doesn't even recognize when docked any more. reinstalled all software and drivers, still didn't work. Purchased new dock and another power cord. Still doesn't work. However, after reinstalling duo stage and then duo station, it came on ONE time and then no more (with photo frame or clock choice) but still no charge. Haven't got it to recognize duo station dock since. Any suggestions would be appreciated. I love my duo and used the dock a lot.
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
SOURCE: my speakers aren't working/says no
Hi , just visit Dell web site and download/install the Audio Drivers for your model of P.C./Laptop. Try this link and start there, it has different options of how to get the right Drivers you need. Just click the information as reguards your Machine..
http://support.euro.dell.com/support/downloads/index.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&~ck=anavml
SOURCE: i have the Dell 5650 Computer Speakers and first 2
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers” Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio Devices, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced),“not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. “Did this solution help?”
