Question about HP Pavilion Computers & Internet
How to fix error 0X80070057 on HP Pavilion Slimline s3323?
I was trying to install a netgear WNA3100 wireless adapter on my HP Pavilion desktop. I got an error message 0X80070057. I need help how to fix this error.
Posted by rfcecala on
Luke Carter
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Hey buddy,
I was also suffering from this problem recently. I have tried many things but not got the solutions. Then one day I was researching and came across this wonderful article. I have tried step by step instruction and my problem got fixed easily.
You can read the link by following the link - https://www.microsoftwindowssupportnumber.com/blog/fix-windows-update-error-0x80070057/
Posted on Jul 31, 2019
Brian Sullivan
  • HP Master
  • 27,725 Answers
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
To fix 0x80070057 errors you need to follow the steps given below:
Update Windows driver:
An obsolete driver can be one reason for causing this error problem.
Therefore to remove 0x80070057 errors message from your system you need to update your Windows driver.
For that you must
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html also
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Registry repair: Corruption to the registry can cause 0x80070057 errors to appear. Registry is the storehouse of files and program settings. Therefore frequent access to the registry key can cause corruption to it. Therefore you need to to repair the
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
registry. also http://download.cnet.com/ccleaner/
If the error problem still remains in your system then it is recommended to
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
It might be possible that due to virus or malware has infected your system that's causing 0x80070057 errors.
The anti spyware software will remove the viruses and make your system clean.
Hence increases the performance level of your system.
all of this is freeware
hope this helps
if there are any stubborn drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
Posted on Sep 21, 2012
1 Related Answer
tom416546
SOURCE: How to fix an Error
-5001 : 0xffffec75
Posted on Nov 09, 2011
Windows 8 computer won't detect netgear n300
It might not need for WIn8 to detect the adapter. when that screen appears cancel/close of otherwise kill the process and see if the adapter is recognized in Device Manager without any error icons.
Aug 05, 2017 | NetGear WirelessN 300 USB Adapter WNA3100
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
I just bought the NetGear wireless adapter today. the process runs smoothly until it asks me to hook the wireless adapter. A box pops up stating "detecting wireless adapter" it stays like that...
It looks like your NetGear WNA3100 is dead out of the box.
The software looks like it operating correctly (runs the installed diag, tries to detect, etc.), but
the software isn't having any luck finding the hardware.
The reason that the adapter is disabled in Device Management, is that the software seems
to have correctly installed the driver, but Windows couldn't detect (plug & play) the device, so
Windows didn't enable the device driver - Windows won't load a driver for a non-existent device.
Other (remote) possibilities:
(a) Wi-Fi adapter plugged into a bad USB port. - try another port.
(b) there's a little corrosion on USB contacts of USB port or WNA3100. Try plugging adapter
in and out of the port a few times (this shines up the contacts a bit).
(c) there's a slight misalignment of contacts within the USB connector or either the laptop, or
the WNA3100.
Your fix may be returning the NetGear WNA3100 to the retailer for an exchange.
Sep 04, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
I have Windows 2000 and my netgear wireless - n - usb adapter wna3100 will not install. I get an error each time.
Netgear does not have Windows 2000 drivers for this product. They are only showing drivers for Windows XP, Vista, and 7.
Mar 02, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
My WNA3100 adapter won't install; it practically freezes on "Detecting Adapter...". I read that Windows 7 sometimes installs these automatically, and mine did that, but I don't see the Wireless...
If the resource CD does not work then I would recommend you to download the installation software for the adapter from the below link:
http://kb.netgear.com/app/answers/detail/a_id/17393
Install the adapter using the software available on the link above.
I hope this information allows you to resolve this issue.
Regards
Anand
Dec 31, 2010 | NetGear WirelessN 300 USB Adapter WNA3100
My resource cd is scratched how can i install my wireless-n 300 usb adapter wna3100
could spread some toothpaste on the cd, wipe it off then try the install again. used to work for me when i had scratched cd's
Dec 28, 2010 | NetGear WirelessN 300 USB Adapter WNA3100
Computers & Internet Logo
314 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
