Question about Samsung ML 2010 Laser Printer
SOURCE: Can I print in Dos Programme with USB Printer
Assuming the printer can understand DOS coded printouts (which most should be able to), you can do it like this: Go to Control Panel | Printers | ML 2010 and share the printer. Then go to a command prompt Start | Run | type cmd Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type NET USE LPT2: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES at a command prompt. Now you can print to LPT2: and the output will go to the USB-connected printer. To find your computer name, right click on the My Computer icon (either on your desktop or the start menu) and choose properties. The window that opens will have a Computer Name tab.
Posted on Aug 28, 2007
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Posted on Apr 11, 2009
SOURCE: i am using samsung ml
http://www.fixyourownprinter.com/forums/printer/59558
Posted on Apr 19, 2009
SOURCE: i am using samsung ml 1640 printes
pls give the patch file for reset the samsung monochrome printer ml-1640 printer.so printer count reset problem.give me a service support from your side.
Posted on May 06, 2009
SOURCE: red light blinking, first orange then red, toner blinks green
dear sir
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Posted on Aug 18, 2009
Aug 18, 2014 | Samsung ML 2010 Laser Printer
May 17, 2010 | Samsung ML 2010 Laser Printer
Oct 06, 2009 | Samsung ML 2010 Laser Printer
Aug 17, 2009 | Samsung ML 1610 Laser Printer
May 16, 2009 | Samsung ML 2010 Laser Printer
Jan 19, 2009 | Samsung ML 2010 Laser Printer
Jun 30, 2008 | Samsung ML 2010 Laser Printer
Jun 19, 2008 | Samsung ML 2010 Laser Printer
Oct 22, 2007 | Samsung ML 2010 Laser Printer
73 people viewed this question
Hi L. E. Levenson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Did you refilled your toner cartridge?
