Question about Razor USA Toys
No power to propel scooter..I get the red power light below is on
Hello, just recently replaced batteries on the scooter. Everything worked great and then while riding myself with my 6 yo, the power went out. I thought it overheated so I waited with no change. I removed the cover and re-checked the battery connections, all looks good. The red power switch light turns on red below but there are no power indication lights "on" the handle bar near the throttle...I did notice a pinched wire near the battery and metal cover...could that be the cause? or did I burn out the motor? but the handle bar lights should still turn on though...right? help!
Posted by Steve on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Posted on Jan 15, 2007
Anonymous
SOURCE: schwinn s-400 scooter no motor activity.
I had same issue, bought a new controller. 40 bucks from the manufacturer. Works great.
Posted on Nov 03, 2008
Dennis Yachimec
  • 79 Answers
SOURCE: no power to starter 2004 chevy tahoe
Hi
It could be your neutral safety switch. It could be the starter relay which is located in the fuse panel box. It could be the smaller wire going to the starter could be loose or corroded.
Posted on Apr 01, 2009
Neil McRobbie
  • 191 Answers
SOURCE: My 2000 Honda Valkyrie won't start. Replaced the
First check battery connections...
then check Ignition fuse
then check your interlocks...in neutral, sidestand up....kill switch to RUN...also try using clutch in case the neutral switch is not grounding the starter circuit properly.
Posted on Apr 01, 2011
adamfjeld
Adam Fjeld
  • 1508 Answers
SOURCE: Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Posted on Jun 26, 2012
I recently replaced batteries. now am getting power lights fast flashing and chair will not move after several try;s the chair will turn on
Just recheck your wiring. If there's 2 batteries, then starting from one side....positive to scooter, then neg from this battery linked to pos on next battery, then negative to scooter.
Dec 31, 2015 | Pride Jazzy 1113 Power Chair
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Have a Panther Scooter and we want to replace the battery, how do we get to the old one.
Jean you have to remove the seat then the rear shroud and you will find the two batteries strapped into the frame disconnect the battery cables from the wiring harness and lift the batteries out of the scooter remove the cables from the old batteries and reinstall the cables paying attention thast you connect them like they were on the old abtteries ie red to positive posts and black to negative posts. Reinstall into the scooter strap down and turn the scooter on to make sure that you have power. If everything works correctly reinstall the shroud and the seat then charge the batteries before use and you should be good to go Charge the batteries every night and they should last a good while Hope this helps you
Mar 16, 2011 | Invacare Supply Group Invacare Scooter...
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Mobility Scooter - Golden Companion 1
Please make sure you FREEWHELL lever located at the rear is in drive mode, if you can push it, move the level.
Aug 03, 2008 | Transport Schwinn Rechargeable Portable ...
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Toys Logo
43 people viewed this question
Top Razor USA Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
