Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Same power supply board LG L1910s and L1510s ?
I have monitor LG L1910s with bad power supply board. Can i use power supply board from LG L1510s ?
Posted by stephan_zivk on
francoise cleofas
    Genius:
  • LG Master
  • 2,432 Answers
Just look the amper rating in the power supply if they are the same.
Posted on Sep 22, 2012
1 Related Answer
caroldon
  • 17130 Answers
SOURCE: I want by a power supply to LG FLATRON L1510S
The question is not very clear and if this is a commercial request it would be better that you can contact any of the power supply distributors in your area. However if the LG SMPS is required it must be sourced from the LG service support.
If you need to check on the SMPS please check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Nov 21, 2011
Nov 21, 2011 | LG Flatron L1510S 15" LCD Monitor
Lg L1510S LCD starting time light is working ,after 5sec light is going.
Sounds like the electrolytic capacitors on the PSU board (ADP-30EP REV B
Sep 13, 2011 | LG Flatron L1510S 15" LCD Monitor
Have a lg l1510s monitor and the power green ligt
Have you tried to substitute a different cable? Many times a cable can go bad, and you cannot tell, because of how they are made. Get a different cable to try as a replacement, and see if that doesn't resolve this issue.
-a.
Jul 02, 2009 | LG Flatron L1510S 15" LCD Monitor
Dark display about 1h. when swicth on.help me pls.........
I'm going through the same thing with a Dell 1905FP - it has 3 bulging capacitors on the Power Supply/Inverter board, and I suspect they are the culprits. At first it delayed a few seconds to start (green power light flashing in all situation), then it took about 10 minutes, then delayed about 45 minutes, then went all the way to about 6 hours - all within a week. When it did come up after the delay, it was perfect. Now it won't come up at all....
It's out of warranty, Dell will have nothing to do with replacing this common failing board, and the replacement board is $50 from an online LCD repair shop.
I'm trying the capacitor replacement tomorrow - they're about 25 cents each... it's worth a try.
Jun 04, 2009 | LG Flatron 775FT 17" CRT Monitor
Monitor LG l1910 S that does not function
hello, maybe you supplier is damaged, and this iss the problem
you can solve it with a simple check by multimeter if the supplier gives you more then 9v his ok.
thank you, ron
Mar 17, 2009 | LG L1910S (Silver) 19" LCD Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
335 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
