Vizio 42 in. LCD TV Logo
diana schrieder Posted on Sep 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i shut off automatic room adjustment - Vizio 42 in. LCD TV
Anonymous
Level 2:
New Friend:
  • Expert 120 Answers
  • Posted on Sep 20, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
120
Questions
0
Helped
34604
Points
381
Menu
select picture
scroll down to advanced video and select it
scroll down to advanced adaptive luma turn it off
and then turn off back light control
that should help with the annoying auto adjusting
Why does my lasko 5842 model keep kicking off and I keep the filter clean
answer is in instructions
Save-Smart®
Press () to activate the Save-Smart®Function.
1.Set the thermostat to desired temperature using the +/-
buttons (Note: The default Save-Smart®temperature is 72 ? F)
2.When you reach the temperature at which you want to
set the unit, the set temperature will flash several times
and then the display will return to indicate the current
room temperature and will gradually change as the
room temperature changes.
3.When the air temperature is less than the set temperature,
the heater will run in HIGH heat.
4.Once the thermostat reaches the set temperature the heater
will automatically switch to LOW heat to save energy.
5.When the air temperature reaches 4? above the set temperature,
the heater will turn off. The Heater will cycle off and on in the LOW
mode to maintain the set temperature.
All this happens automatically with Lasko Save-Smart®Technology.
To deactivate the Save-Smart®function, press Save-Smart®
again or (hi/lo) for continuous high/low heat.
AUTOMATIC TEMPERATURE CONTROL(Figure 3)
The automatic temperature function will only operate on "High" heat.
You cannot set the temperature automatically when the unit is in the low heat mode.
1.To set the room at a specific temperature press the () or()buttons
to the desired temperature. The display will now reflect the () and the temperature will be flashing. The Heater is now in Auto Temperature Mode.
2.When you reach the temperature at which you want to set the unit, the set temperature will flash several times and then the display will return to indicate the current room temperature and will gradually change as the room temperature changes. NOTE: the temperature display does not indicate the temperature of the heated air being emitted by the heater.
3.Once the room temperature reaches 2 degrees above the set temperature, the Heater will shut off. Once the room temperature reaches 1 degree below the set temperature, the Heater will turn back on and continue to cycle off and on to maintain the set temperature.
4.This function will cancel if the ()button is pressed. The Heater will now be in High heat and run continuously.
NOTE:It is normal for the Heater "fan" to run for approximately 15 seconds when the Heater shuts off after reaching the set temperature.Press the () and() buttons at the same time to change the display to ° Celsius. Press the same two buttons together again to change the display
back to ° Fahrenheit.
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
1helpful
Need owners manual online what is the auto button for
Auto enables the unit to adjust the temp automatically as temp in the room changes. It will change to cool mode or high fan according to the temp in the room.
Adjust thermo on a split system
Remove the front cover on the room thermosat and theres a dail that has #,s on it and this is called a heat antcpator, which add heat to the thermostatto sht the unit off ahead of time. To correctly find the rght setting you need to pull an amp draw.
Furnace burner turns off and on
The furnace is likely over heating and the high temp. safety is shutting it down. It then cools and starts again. Things to check: Filter, Blower wheel and indoor A/C coil. If any or all are dirty you are limiting air flow and need to clean them.
I have baseboard heat in my house (hydronic(?) - not electric). The 3 bedrooms upstairs are always 3 VERY different temperatures. My daughter's room is always cold, sons' room is like the Sahara and our...
what it sound like is that your sons room is the closest room to the boiler and is getting too much of the heates water. your room is probebly the room in the middle and your daughters is the last one. Lets start bye taking and shutting down the valves in youe sons room and or adjusting the circuit setters which is what you probebly have . THey should by on the return line and you can adjust them by just closing them down a little bit at a time or if you have a way to take the temperature of the return and the supply lines then you would try to shoot for around 10 delta t. look at the baseboard heaters where the water come in and that should be where you will find the circuit setters. Good Luck and have a Merrry Christmas
4helpful
2answers
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
1helpful
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
