No I don't, but you could look for a local TV repair shop in your area. Try and shop around and see if a shop will offer a free diagnosis. Watch your costs, repairing the set could exceed the cost of a new set.No I don't, but you could look for a local TV repair shop in your area. Try and shop around and see if a shop will offer a free diagnosis. Watch your costs, repairing the set could exceed the cost of a new set.
You can't post conmments that contain an email address.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
On projection types, figure on just replacing the entire board that has the flyback transformer on it.
