Question about Kodak EASYSHARE CD1013 Digital camera compact 103 Mpix optical zoom 3 x supported memory MMC SD SDHC
I have a CD1013 and it no responds, new batteries, no image, dead...?
My camera completely non-responsive.
    Genius:
  • Kodak Master
  • 1,019 Answers
You said the word my friend "DEAD" as in shop time, no easy cure for this.
Posted on Jan 24, 2013
rajdeepdutta
RAJDEEP DUTTA
  • 2517 Answers
SOURCE: EasyShare CD82 non-responsive - Lens stuck open
Hi there its a problem of lens guide pin. may its damaged or dislocated. Its a possiblety of company manufacturing default. So repair or replaced that. Its till under werranty. Thanks. bd4ebca.jpg
Posted on Apr 02, 2010
Alcatel one touch fierce was working fine with 75% battery life, a min later it was turned off and won't respond to any buttons or rebooting combinations.
As long as you didn't get it wet, or root it. I'd go ahead w/ the warranty. There are "unbricker" programs that can take a completely non-responsive phone and bring it back from the dead, but I'm 99.99% sure they're all designed for bricking caused by bad rooting procedures.
Nov 29, 2013 | Alcatel Cell Phones
No response from gas pedap no rpm
Is the battery completely dead
You may be loosing computer module
voltage,sounds like that symptom
Mar 02, 2013 | Cars & Trucks
I got this camera last June and it's been dead since January. Every time i try to charge it, it will not respond to the charge.The battery is completely dead, but when the charger is plugged into...
Hi, Sounds like the battery is toast. Batteries can stop charging any point in their life span. Usually I'd suggest just buying a new battery but because a battery shouldn't die like that within the first year I'd suggest contacting Nikon in your country and seeing what they'll do for you.
May 18, 2011 | Nikon Coolpix S4000 Digital Camera
My D80 is suddenly dead. I was uploading photos to my computer yesterday. After most of them were uploaded, an error message popped up saying an error kept it from uploading the next one. It kept popping...
This is why the pros always use a card reader instead of the camera. When you disconnected the camera, did you remember to use the "safely remove hardware" function? The computer was obviously still trying to write and communicate with the camera and if you just disconnected it, the camera became corrupted. Check your manual for instructions for a camera reset. Try that. Also, remove the card and batteries, press every button, leave it alone for 20 minutes, insert the card and then the batteries, turn it on. Sometimes this works.
Oct 10, 2010 | Nikon D80 Digital Camera
Why can't my kodak easy share cd1013 download from my camera
Having gone over a month without a response, I assume this is no longer a problem.
Jun 27, 2010 | Kodak EASYSHARE CD1013 Digital camera ...
Photosmart R727 charging blinks never stop, camera never responds
Remove the battery, connect the camera to the charger and try the camera. If it works, it means you need a new battery.
Jan 04, 2010 | HP Photosmart R707 Digital Camera
Can the kodak easyshare cd1013 be used as a webcam?
i have a kodak easyshare CD1013 that has had three sets of kodak new batteries put in and it still want turn on. i don't have a sales slip sence it was a gift but it would be under worrenty
Jun 19, 2009 | Kodak EasyShare C315 Digital Camera
Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Mar 24, 2009 | Kodak EasyShare One Digital Camera
Kodak EASYSHARE CD1013  Digital camera  compact  103 Mpix  optical zoom 3 x  supported memory MMC SD SDHC Logo
47 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
