Every time I get on skype to talk to family or get on netflix, after a couple of minutes, the computer freezes completely and begins to make a sound. I cannot move the mouse at all.The only way I can get out of it is by doing a hard shut down on the computer. I've uninstalled and re-installed Skype, but the problem still persists.
see if this link helps you out.
Skype Netflix doesn work Google Search
SOURCE: i cant hear the other person in voice chat
since you are facing problem with all the IM's. check the connection speed. sometimes even EDGE is not enough for voice chat. try it with a better bandwidth connection.
SOURCE: I am using Lenovo Y510, the integrated web cam is
Ok first open the yahoo messenger then go to tool setting and select you web cam.
SOURCE: Computer Shut Down Problem
Is the computer taking forever to shutdown in the blue screen or is it something else. Perhaps try closing the applications running with the system to help the process speed up and actually work without the usage of the power button.
SOURCE: have a lenovo 3000 n200. had just removed skype
Did you run the uninstaller to remove Skype? You may have removed something you should not have, like a your display driver. Anyway for starters, remove the battery and after a minute or so, refit it. This will clear all spurious data and give you a clean start. If still dead, You will need to re-install your operating system from the CD.
SOURCE: My G550 lenovo just started shutting Windows down
go control panel
then power options
then find on the tabs power scheme
then try putting the turned off hard disk (never)
