Scan to email works but scan to folder does not. I have checked permissions and path and still no luck.
SOURCE: Canon imageRUNNER 5000 scanner
yes it can if you have the scanner driver borad loaded in the machine
Thank You,
Mikey
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
SOURCE: Canon Imagerunner 2020i scan to pc- set default send to address
you need to store that location in the address book, its under additional functions, once there you have to enter info for scan location
SOURCE: Canon 6570 Copier Scan to a network file share, not email it
the easiest way to do this is to goto additional functions, address book, register new address, file, then you can type in the name you would like ie. Bill or Contracts. when it asks for the file path change it from ftp to smb and then select browse this will let you browse the network and just select till you get to your shared file. you can also type the ip address in the address bar of internet explorer and manually put the file path in the RUI under address book.
Testimonial: "This was great info and very quick. It is great to network with others and hopefully I can do the same for someone else down the road."
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
