SOURCE: GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
SOURCE: GE Advantium mircrowave oven
The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
SOURCE: replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
SOURCE: Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
