SOURCE: flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
SOURCE: Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
SOURCE: Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
SOURCE: WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
