Question about Polaroid PhotoMax PDC 4055 Digital Camera
Need software to send pics. to comp.
You don't need any software for that.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Posted on Sep 20, 2012
SOURCE: HI - OPERATING INSTRUCTIONS FOR POLAROID PDC 4055
How do I get another copy of the operating instructions book? I can only take 10 pictures then the camera is full. What is wrong?
Posted on Mar 08, 2008
SOURCE: lost software
I would check out the polaroid web site, you should be able to download from there.
Posted on Aug 05, 2008
SOURCE: polaroid pdc 4055
The SD card.has a small notch that is used to lock..usually on the lower right corner of the chip. Move the notch to the other end to unlock the card.
Posted on Nov 13, 2008
SOURCE: No software to load pictures onto my pc
if its digital and you have a card that goes into your camera, you can take it out.. put it into you compuer reader if you have one on your computer, its a slot for the sound card, if not you can buty a card reader..its called scan disk. it takes 4 sizes of cards..intalled this on your computer and then put your card into slot and you should beable to see your picture on computer. . or go onto google and type your camera name and downloads and c if they have anything there.or call the manufature of the camera to see if theyll send you another at a cost. hope this help
Posted on Jan 22, 2009
