Ovens Logo
Anonymous Posted on Sep 19, 2012
Kenmore Oven- The oven doesnt heat or light at all. If I sent it to 350 degrees; should i still smell gas?
Kenmore oven model # 362.75201890 ser# 8M114418P. Were can i find a manule for this???
Anonymous
Level 2:
New Friend:
  • Expert 79 Answers
  • Posted on Sep 19, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
79
Questions
Helped
24837
Points
268
I beleive this model has an electric igniter, You may have to change this they sometimes just wear out, or it's just simply your pilot light is out and you need to relight it, hope this helps.
  • Anonymous Sep 19, 2012
    the igniterhas a split in the stone at the end of it. Would that mean its bad?
    if you open your oven when you try to light it you should hear the igniter trying to light the stove if not replace it, if the split looks like a crack then yes replace it, 9 times out of 10 that is the problem.
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 79 Answers
  • Posted on Feb 28, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
79
Questions
5
Helped
169338
Points
102
I believe this PDF manual can help you - Kenmore Oven Manual
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Nov 07, 2007
SOURCE: gas leak from oven
Sounds like the ignitor is weak and needs to be replaced. How old is the oven and what is the model # from the sticker on oven?
Anonymous
  • 183 Answers
  • Posted on Nov 17, 2007
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Anonymous
  • Posted on Feb 02, 2009
SOURCE: Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Anonymous
  • 117 Answers
  • Posted on Feb 25, 2009
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Anonymous
  • 3361 Answers
  • Posted on Oct 05, 2009
SOURCE: My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
My oven is taking 30 min to heat up to 350 degrees. the light sensor is turning orange what might the problem be??????
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
1helpful
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 • Ovens
1helpful
Kenmore gas oven does not reach operating temperature
If your oven is 20 years old the temperature sensor system might no longer be accurate, if you have access to a temperature measuring device that can confirm that the oven is not reaching 350 then run it up and check that its not just your indicator light system. Some oven burners have air control and yours may have accumulated oven soil over the years. If your burner. Is behind a short wall like mine is, use a mirror and torch to check. A clean can bring things back to standard. Flame heat is from a good mix of. Gas and Air...
My Kenmore gas stove has a light constant smell of gas coming from the oven. The oven also does not heat any longer. Burners work fine. Model 970
There is a problem with the regulator or the thermal bulb you need to call a repairman in to replace it, if you have a gas smell it is allowing the piolet light to have gas comming out and not lighting this is DANGROUS do not put it off get it looked at right away. This can kill you.
2helpful
On my gas kenmore oven, the oven first wouldn't get up to temperature, and now 3 months later it just doesn't heat at all. There is no gas smell or indication that there is a pilot light. My gas broiler...
Replace the glowbar ignitor in the oven. Turn off the gas supply. Remove the oven racks. Remove the base pan in the oven to access the ignitor. Most plug in. Some have wire nuts.
Your local appliance parts store will need the model number or the ignitor for a correct replacement.
1helpful
Set oven to pre-heat to 350; won't go above 100 degrees
could be one of 3 problems: missing 240volts and only have 120volts(one leg out)/bad element(chk for "hot-spot") pitted and discolored-it will soon break there/or the thermocouple is bad that senses oven temp
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
3helpful
2answers
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
