Unplugged the unit, and went on vacation for 2 mos. After power up, error code F60 is all I get. No buttons work. Pushed reset button 10+ times, same result
After reading and trying these solutions with out success, what I did was climb to the top of my roof and throw the Panasonic unit onto the cement driveway. The end result was the unit still won't work but darn I feel much better. No Mo Panasonic electronics for me, thank you very much!!!!
I had the same problem -F60 error after pressing the power button until the time appears. At first I used the reset button , then held the channel up and down buttons until it shut the unit off, but still got the F60. I then shut the unit off overnight and when I plugged it back in and Setup appeared after the blinking hello, I turned off the quick start option and it completed setup without any further errors. I also manually deleted the broadcast channels that had no signal before proceeding. Hope it works for you too!
Read your owner manual, see the section troubleshooting and proceed according. if you do not have it download from www.retrevo.com or
www.fitness.manualsonline.com
God bless you
SOURCE: Panasonic DVD and video recorder.
you hav a power issue. replace the power box now while its cheap. hope that fixed ya.
SOURCE: Any button pushed on my remote control causes ''SET 1'' on display.
Hi, All you need to do is point the remote at your DVD player and hold both the number "1" and "enter" keys down for about 10 seconds. Evidently that re-sets the remote. It worked for me so good luck.
Pete
SOURCE: F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
SOURCE: Panasonic DMR-EZ48V stopped working properly. It
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
The owner manual does not have any code F60 listed. Thanks
you must get contact support to the company supplier or factory, for to erase and fix it. God bless you
Error F-60: More chance bad the HDMi PCB check: avsystemparts.com
