Does anyone know where to get an Icc color profile for this monitor? I can't find the manufactures website.
SOURCE: monitor goes blank
Sometimes, i can be the wiring, so check all of that. But apart from that. I don't know! Hope this helps!
DigicalJAI
SOURCE: the monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
SOURCE: princeton vl1717 monitor say signal
Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: I received a Princeton Monitor
Blue tint means taht you may have bad video cable or bent pins, check both ends of the video cable first and also try flexing the video cable to see if the problem will gome and go. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
SOURCE: Need to know the amps of this 12V power supply for this Princeton Monitor
That unit uses a power supply 12v 4-5 amp such as this one:
http://www.ccl-la.com/catalog/product_info.php?products_id=48
thanks for the suggestions. what I am trying to do is match the colors on my scanner with my monitor.
