Dodge Master
- Posted on Dec 27, 2008
Re: # 4 fuse blew out, replaced fuse and keeps blowing ....
I KNOW YOU HAVE AN ELECTRICAL SHORT.WAS AN ALARM INSTALLED OR ANY OTHER TYPE OF ACCESSORY? CHECK WITH DODGE TO FIND OUT ABOUT A RECALL.IF SOMETHING WAS INSTALLED, TAKE IT BACK THERE TO STRAIGHTEN IT OUT IF NOT HAVE A AUTO TECHNICIAN CHECK IT FOR YOU.
oh thanks for responding, didnt think i would get a response. Any ways after working on it for hours i traced it back to the license plate wire, right where the spare tire is mounted. the tire smashed the wire against the frame exposing the wire and grounding out casuing the short.
no head,frog lights not working.
Upper + lwr fuses and relays are ok.
Every time my husband presses his brake pedal the fuse for the brake lights blows!? What to do to fix this problem?
Need to change fuse.. but don't know witch one is tail light fuse.
fuses keep blowing power locks, heat , and cig light all not working
blew fuse #7. replaced it. now check engine light is on
THE FUSE BLOWS AS SOON AS YOU TRY TO REPLACE IT
Brake Switch. All other lights work fine
Have already changed brake light switch
