Legacy Audio American Legacy II LA590 Car Audio Amplifier Logo
A
Anonymous Posted on Sep 18, 2012
What size fuse goes in a legacy LA590 - Legacy Audio American Legacy II LA590 Car Audio Amplifier
2 Related Answers
Anonymous
  • 63 Answers
  • Posted on Mar 06, 2010
SOURCE: legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
devon_m_smit
Devon Smith
  • 10 Answers
  • Posted on Aug 15, 2014
Bad ground or bad power or if it's going into protect the wattage of the amp and wattage of the sub are mismatched. Assuming you are powering a sub? Possible issue with impedence. E.g. sub is 2ohms amp only 4ohm stable. Etc
What size fuse do you need for a Legacy Sapphire LA-695 4 channel amp?Doesn't say fuse size on the amp
Is there a 20 or 30 amp fuse plugged in to the amp near where the 12 volt connection is?
Usually, if an amp blows a fuse: something caused it.
You must remove that cause, before you replace the fuse or it will just pop another one
Can my la590 American legacy 2 series 800 watt handle Boss CX122 Chaos Exxtreme 12-Inch Subwoofer 4-Ohm Voice Coils??
It is only stable to 4 ohm mono(which is 400 watts RMS or a bit less not the max rating of 800 watts which is a PMPO rating).
Your Sub would have to be wired in series(8 ohm final load, if you wire it in parallel 2 ohm-you will fry that amp).
2answers
Legacy audio LA590 car audio amp protecet mode
No wired bass control knob - reply back from original posting
i would not worry about that really you dont need it i know install more than five hundred of them
I need a remote control bass knob and cable for a Legacy LA590 2
Most of the remote bass control knobs & connectors are the same, regardless of manufacturer. Granted there are different styles & connectors used, but just find one that's compatible with the amplifier you have. You don't state what amp you have (at least I don't see it in desc.) Send me some info & I'll get back to you tonight. Bruce McGowan [email protected]
1helpful
HOW TO HOOK UP
Try Legacy Website legacycaraudio.com you may be able to download the manual with installation Instructions.
NO SOUND, NO POWER
try different rca cables and also different speaker wiring to the amps and see what u get
1helpful
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Power problem
Do you actually see a fuse in it? If there is a fuse it should typically say on it what the rating is.
Top Legacy Audio Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
